JMB RetrofitsEM Tuning
Results 1 to 7 of 7
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Valve under S3 inlet manifold?
    Just under the plastic cover on the metal bracket
    Whats it called?
    At first i thought it was the N249 valve but i was wrong
    Ross_S4
    Aug 2009
    Dundee
    718
    Alright mate
    not sure what it is called but on my 1999 APY, the bit you describe is called a solenoid changeover valve and the part no is 029906283H and it appears to open and close to control the secondary air inlet combi valve.
    Ross_S4
    Aug 2009
    Dundee
    718
    and i don;t know the price however i would guess about 40-50 quid.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    EGT probe connector box.... fixes to bottom of the inlet mani...
    <tuffty/>
    Jun 2009
    Leeds
    3,469
    Anyone got a good spare one?
    If not i'll pop over to Audi
    S3 Paul's Avatar
    Oct 2006
    2,764
    As tuffty said . The box that is bolted to the bracket under the inlet is the EGT connection box. The aint cheap either,
    Ive bought one and didnt like the bill one bit,
    Noggy Blue 2001 S3
    Ross_S4
    Aug 2009
    Dundee
    718
    okay so depends on your engine then whether it is the egt sensor or the solenoid, I see from your previous posts that it has a couple of hoses attached and one has snapped?
    Remove the plastic cover, if there is an electrical connection to the left of the dipstick it will the egt sender (G235). If what you are referring to is bolted on the bottom of the metal bracket with an electrical connector and two hoses coming off it then it is probably your solenoid for secondary air inlet.
