Results 1 to 18 of 18
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    G60 Flywheel & VR6 Clutch???
    Hi,Ive read up that some of the Golf 1.8T boys with a remap fit the G60 flywheel with the VR6 clutch??.anyone done this or know more about it?.
    A3 1.8 TURBO| RS6 18INCH ALLOYS | FORGE 007 | SMOOTHED O/E BOX WITH COLD AIR FEED | COILOVERS | MOTECH RE-MAP | FULL CREAM LEATHER | FORGE DV RELOCATION | FORGE TIP HOSE|SILICONE BOOST HOSES|REMOVED REAR WIPER|G60 FLYWHEEL & VR6 CLUCTH|MILTEK CAT BACK DISCREET SYSTEM|312MM BRAKE UPGRADE|UPRATED DOG BONE MOUNT.
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,361
    Hi Steve, I'm running the g60 flywheel and VR6 clutch in my A3, and it's brilliant.
    The standard G60 flywheel weighs 10kg, which is already lighter than the dual mass standard flywheel, and would make a good difference.
    Mine has been lightened down to 6kg, and it's absolutely great.
    I'm using the LUK VR6 clutch kit, which mates directly to the g60 flywheel, and is rated to just over 300lbft.
    You also need the g60/ABF flywheel bolts, as the standard ones are the wrong length.
    THe flywheel you need is often refered to as G60, but it's also the same as that fitted to the ABF engine, which is the 2.0 16v fitted to the mk3 golf gti.
    All in all, it's super cheap to do, around 100 for the flywheel brand new, 100 for the clutch kit, and I paid 100 to have it all lightened and balanced.
    The difference is great too, it picks up a LOT faster and feels way more responsive. it's also a really nice pedal feel, and not bitey at all.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Is this just for 06a engines ( ie a3's) and will it fit a4's
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Prawn sounds great mate,have you got the part numbers for the clutch etc please or where to get it all please dude?.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    not got any part numbers dude, they're not really needed.
    Walk into a VW dealer and ask for an ABF flywheel and bolts
    then walk into GSF and ask for a clutch kit for a golf VR6.
    job done
    TDIQ's Avatar
    8L > 8P > 8V
    Jul 2009
    777
    Would this be of any benefit on a 1.6 A3 or a waste of time and money?
    '02 A3 TDI quattro sport
    8L IS DE BEST
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,317
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    waste
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Cool beans Prawn.So you reckon around 200 for the clutch and flywheel?
    barters3's Avatar
    May 2008
    440
    Is this set up recomendable for an s3? Im getting mine remapped soon and my clutch has done 103k,so i need to look into a good set up should my clutch go.
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    No idea on the S3 mate as it has a 6-speed box so dont know if it has the same set up.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,361
    no, sadly it won't fit the S3 box I'm afraid!
    Steve: I'd really look into getting it lightened if I were you!
    it makes such a big difference, with no downsides at all
    Jun 2009
    1,069
    Does that inlcude my 6 speed too . I hope not!.
    Its gone replaced with a mk2 golf gti 16v :D
    Apr 2004
    12,520
    The 6 Speed cars (A3/S3) have a 240mm clutch/ flywheel where as the G60 combo is only 228mm so will not work
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    Is there anyway i tell if it is the right flywheel from a G60 as ive been offered a few flywheels from the ABF??
    andy121's Avatar
    19
    Quote Originally Posted by steviet View Post
    if its from a ABF then it will fit. you can use a G60 or a ABF flywheel but not a VR6 one (they have a different blt pattern)
    steviet's Avatar
    Sep 2008
    ESSEX
    432
    So what cars have the ABF flywheel mate?..i know the G60 % MK3 16v have it,ive also heard that the passat has it to??.
    andy121's Avatar
    19
    G60 is the engine used in a Golf Mk2 G60 (suprisingly) and also in a g60 passat and anything else g60 powered
    ABF is the engine code from a Golf Mk3 16v GTI and again its used in a Passat and also some Ibiza's (anything mid 90s FWD VAG group 2.0 16v basically)
    Sep 2010
    38
    will this work in a T reg 1.8T as im really considering it?
