Results 1 to 13 of 13
    lloydsta101's Avatar
    Bristol
    134
    Forge 007P Dump Valve Spring question.
    Hi all,
    I've seen in a few threads that most of you are running the Green/Yellow springs depending on re-map and cars performance etc.
    My 007p DV came on Tuesday and I was going to fit it this weekend, but out of curiosity I opened it up to see what spring was in there. I found that there was neither a Green or Yellow spring, but two Grey/Metal springs pushed together inside (one sitting in each piece of the dump valve).
    Is this normal, as I've never looked inside one before and not sure weather this is how it was supposed to be? It was fitted to a car before as I bought it used, so can I just fit it as it is?
    Eventually I will be getting a remap, so will get one of the coloured springs but it might not be for a while... so just checking it's ok to use in the mean time.
    Cheers peoples.
    Current: 2007 Audi A3 2.0 TDI (Black)
    Previous: 2000 Audi S3 (Silver)
    Previous: 2003 VW Golf R32 (Blue)
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    That's not right mate, sounds like the previous owner was messing about with it. I'd just get a new spring from forge as their only about 5
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Bristol
    134
    Really, I thought it wasn't right. Good job I'd been reading through a few previous threads then and noticed. Will it cause problems then if it was fitted like that?
    It's got some wear marks around the edges of the bits that fit to the car, so it's either been used like that or the spring has been taken out and replaced with those two since removing it from the car.
    Grr, got to wait even longer to fit it now!
    Westy's Avatar
    Dec 2008
    17,283
    You want to be using the correct spring so that the piston is at the correct tension. I have no idea why you have two springs or what the tension is so it could cause problems.
    S3 Build Thread
    Bristol
    134
    Yeah, fair enough... look's like I'll just have to wait a bit longer then.
    I've found where to buy the springs from on the Forge website (link below), but it seems to be a kit of all four. Can I phone them to buy just one?
    http://www.forgemotorsport.co.uk/con...roduct=FMDVTUN
    Westy's Avatar
    Dec 2008
    17,283
    Use this link mate. You'd probably be best with yellow but most say they haven't noticed any difference between a green or a yellow spring. The yellow spring ships as standard with the 007P valve.
    http://www.forgemotorsport.co.uk/con...duct=FMDVSU110
    S3 Build Thread
    Essflee's Avatar
    Mar 2008
    2,007
    Mine came with the green spring...
    Like badger has said in another post, why make it harder for dv to open ??
    revo'd
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by leggy View Post
    I only said yellow Leggy because my mate at work took delivery of a new 007P this Tuesday and it had a yellow spring in it!
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    Westle the green comes as standard, the yellow is recommened for re-mapped cars but alot of people stick with the green.
    Westy's Avatar
    Dec 2008
    17,283
    The spring in my mates one didn't look very green to me. Anyway green or yellow, there's not much difference but I wouldn't run the valve with two grey springs.
    S3 Build Thread
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,235
    When buying you can specify which colour you want, its just alot of people say the green makes the engine feel more torquey whereas the yellow seems to let the engine down.
    Essflee's Avatar
    Mar 2008
    2,007
    Quote Originally Posted by Westle View Post
    Yeah to be honest does seem a bit random how some suggest green and some suggest yellow, I guess if your happy with either who cares...lol
    Though I have read that having the wrong spring can reduce the life of your Turbo, how true this is though I don't know...
    revo'd
    Bristol
    134
    Thanks for all the help guys. If they come as standard with a Green spring, then I think I will go for that. My car is only standard at the moment, so hopefully that spring will be right for it... like Westle said, either is better than running two bare metal springs. God knows where they came from?
