EM TuningMonster Motorsport
    S3 Dave's Avatar
    Now running on Heavy Oil
    Jul 2007
    Middle England
    432
    N276 Vag com error
    17432. Fuel pressure regulator valve-N276:open circuit P1024
    Can anyone help with a diagnosis of this error found with vag com??
    There is no description for that number 17432 on the ross tech site :-(
    Do i take it the valve needs changing/cleaning the contacts??
    "Never in the field of human conflict was so much owed by so many to so few"
    Churchill August 20th 1940
    S3 Paul's Avatar
    Oct 2006
    2,764
    I would check the connections and the wires that go to the plug... "open circuit " on mine has normaly resulted in no signal from the sensor/ valve
    Noggy Blue 2001 S3
    S3 Dave's Avatar
    Jul 2007
    Middle England
    432
    Yeah need to get out in some daylight and check the connections!
    27,126
    Open circuit would usually suggest a connection issue, check wiring, fuse, plug etc
