JMB RetrofitsVolks Autos
    73
    How often should I service my S3?`
    Hi
    Im an owner of a new audi s3 51 plate with 100k on the clock - i was wondering when should i service my car and how often?
    it was recently done 3 months ago but how much would you guys recommend to keep the engine running pristine?
    the cambelt was done at 99k and has been really well looked after
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Welcome bud! I change the oil and oil filter every 6-8k, use good quality oil and a genuine oil filter, the plugs are ok depending on what you have, the platinum plugs last a while so change them as and when required, if it has a oem air filter then change that every oil change, if you have an after market filter (k&n, green, bmc, piper cross, itg etc) then that would just need a quick look every now and then. I think thats about it really, main thing is oil and oil filter and it should run pretty sweet!
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Haldex every 20/40k (I do filter and oil every 20k).
    Oil every ~5k with proper oil (I like the motul stuff myself) filter
    Pollen / Air filter every 10k (or when it looks ****)
    Plugs more often than needed if mapped.
    Cambelt every 60k or 4 years.
    That's pretty much what I've been doing, along with new short engine and new head depending on which month / year we're in
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Quote Originally Posted by god_thats_quick View Post
    No wonder my plugs ain't lasting long
    My cars done 116k and i don't think its ever had the haldex oil changed, is it worth doing, was thinking of having it done last winter but dreading leaks because its never been changed
