Monster MotorsportVolks Autos
Results 1 to 33 of 33
    73
    S3 startup sounds like a diesel???
    im not sure if anyone else heres this but when i start my car it sounds like a diesel? does anyone else have this issue?
    i have checked my oil levels and everything seems fine and my car was serviced 3 months ago...maybe its me being fussy?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    It's probably the warning sign of the VVT/ timing chain tensioner on the way. As long as it gets quite as soon as the car starts you are fine, when the noise gets worse or does not go away it's time to fix
    73
    whats the vvt?
    the cambelt was replaced in december...the noise only happens on startup not while im driving or when im on stand still.
    have you noticed it ever?
    Apr 2004
    12,523
    Its at the other end of the head to the cam belt. Its under the cover and is a hydraulicly controlled device to tension the cam chain. Some S3's have a variable valve timing feature built in too, depends on engine code.
    If it goes away it's cool
    73
    cheers for the info mate...so would you say its something i need to worry about? or is there any fix?
    do u ever experience it?
    Apr 2004
    12,523
    I don't experience it on my car, but have done on the A3, when it eventually wouldnt shut up we repalced the tensioner and it was a 300 part on it's own.
    Sometimes a good flush and oil change can help, as the long intervals don't do these cars any favours
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    I think some diesel ish noise is a design feature of this engine, especially if it has been stood for a while.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    All S3's sound like diesels on startup. People seem to forget that behind the flared wheelarches and tacky mirrors there's a 4 cylinder 1.8 engine, which has been around since the mid 90's.
    Jul 2009
    South Wales
    37
    Nothing to worry about mine sounds the same on start up...
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Its a character of the 1.8 20V turbo engine nothing to worry about.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    73
    cheers lads i really do appretiate your help - i was really sh*ting myself thinking i got engine issues lol
    Westy's Avatar
    Dec 2008
    17,283
    Most people who have never heard the 1.8 20v turbo engine will be shocked when they first fire it up! It sounds like a bag of nails in comparison to alot of other engines. You get the diesel sound and a load of tapping.
    S3 Build Thread
    73
    thank fully mine only sounds like a diesel on start up...touch wood it doesnt ending up like diesel.
    Westy's Avatar
    Dec 2008
    17,283
    Maybe you bought an A3 TDI with an S3 badge on the back
    S3 Build Thread
    pauldazzle's Avatar
    Cardiff
    639
    It's the secondary air pump housing leaking. Very common problem on mk4 Golfs.
    Here's the fix. http://uk-mkivs.net/forums/t/141240.aspx
    LordNelson's Avatar
    Aug 2009
    167
    Cheers for the link Paul.....gonna whip mine off and have a look maybe this weekend. any quick fix is always worth doing / or checking at least to ensure smooth running
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
    Westy's Avatar
    Dec 2008
    17,283
    Thanks for the guide but i'm not too sure how a loud vacuum noise can be mistaken for an engine sounding like a diesel!
    S3 Build Thread
    73
    so is it the secondary air pump housing leaking?
    i dont appear to be having any leaks is it def this?
    Westy's Avatar
    Dec 2008
    17,283
    Quote Originally Posted by dragonstyle View Post
    Personally if your that worried about it just drop it into a garage for a quick check, they probably say its normal and send you on your way without charging you.
    The sencondary air pump sounds like a vacuum hoover so I doubt it's that.
    S3 Build Thread
    pauldazzle's Avatar
    Cardiff
    639
    Quote Originally Posted by Westle View Post
    If it sounds like a diesel/vaccum cleaner when you start it up, & then stops after a minute or 2, it's the secondary air pump case rivets that have failed. I've had the same problem on 2 mk4 golfs.
    pauldazzle's Avatar
    Cardiff
    639
    It won't cause any damage, but is rather embarassing.
    73
    cheers for the link paul...anyone from the midlands free to help me do this? im not a mechanic and i would appretiate some help
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Quote Originally Posted by golf View Post
    ....there's a 4 cylinder 1.8 engine, which has been around since the mid 90's.
    The block can be traced back to the early 1970's!!
    Jason
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by jcs356 View Post
    Well there you have it then. The engine is even more antiquated than I thought, almost 15 years older than me!
    Biggied's Avatar
    They called him mellow yellow.
    Feb 2006
    Scotland
    202
    just to add to the secondray air pump point, if your secondray air inlet valve fails/sticks in the closed position it can casue the pump to do its dyson impression as its force feeding air into a closed valve. Also worth pointing out is that if said valve fails/sticks in the open position it can cause lean mixture faults.
    Ewan
    210hp 8L S3 quattro.
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Paul....
    I agree with others here. I've personally experienced this fault. Where it's more of a mechanical, gear/chain nasty noise, rather than a sudden rush of air/suction noise!
    Just to add to what others have said here though, my car a 2001 S3 had this problem when i bought it. It didn't put me off, i really did think that it was a heatshield rattling somewhere inside the engine bay or something which was loose, metal on metal.
    However, it turns out that the VVTI unit and timing chain system was at fault. Was advised by Audi not to drive it and to get it done there and then. I.e leave the car with them.
    It does all depend on how bad this is on a particular car but it is NOT supposed to do this when the engine is working as it should, even on startup. All the information i'm stating here comes from Audi GMBH and a main dealer head technician.
    The issue with this failure is the oil return pick up pipework, which has a filter at the bottom end (sump) this when using Long Life service intervals gets cloggy and blocked due to the rough consistency of the oil over a prolonged period of time.
    When the timing chain tensioner has no oil pressure to mechanically work it fails to operate the tensioner, thus leaving a slackened chain. Mine was overly noisy and was aparent during gear changes also. Which was kinda scarey and that is what made me orignially think oh the exhaust is moving slightly and this was the heatshield rattle etc.
    So 500 lighter in the pocket (Dealer agreed to pay 3/4 of money required) i ended up with a complete new VVTI unit, timing chain, tensioner, oil return pickup pipework, metal prop water pump, oil pump, cam belt, sensors and all the other consumables which were required.
    I had a full service carried out, then had another one 3 months later to make sure the oil was nice. Due another one in a month or so. In all fairness the car was and still is running much much nicer. I chose a specialist in the end as i felt that he would carry out a better job and i'd not have monkeys spunking over the car. I'm particular where i take my car to be worked on and i am still very very happy with my choice.
    In my opinion, if you have the money to get the car done now, do it. It's only going to get worse like mine did and you will eventually have to get it done. You could sell the car as is, but if you are like me you love you car and won't want to part with it.
    Just an insight from someone who actually went through it start to finish! Another forum user by the name of NAK has recently done this. He even had two different engine types and used the VVTI unit and timing gear from another engine code to fix his problem.
    It can be done cheaply but i wouldn't want my chain snapping or my car underperforming. Timing chain is a very very important integral part of engines which use this method.
    Hope that helps!
    G
  28. #27
    73
    hi guys
    i just checked my service book and it says the cambelt was done last year in december - so i dont see how the problem can be with the timing belt?
    anyways i was thinking i should just ignore it as it can be a number of things and i may just end up wasting loads of money and may never correct the thing...its only happening on startup and sounds fine on stand still and driving...it could be something that happens in winter and if something does go wrong in the future at least ill know what it is that has gone wrong and ill be able to replace the part - rather than wasting money trying to fix this one thing.
  29. #28
    May 2006
    Surrey
    175
    Dragonstyle- Your Timing Chain is totally different to your cambelt and if you wait for your timing chain to fail it will then be way too late to simply change the part as your engine will be shot.
    If your worried about it then take it to a decent audi garage/ specialist and get them to look over it.
    As a lot of other people have said the S3s do sound crap on start up.
    Audi S3 2001. Black on Black. OE Sat Nav/Freeview. Bose. 18" Audi/BBS Splits. 10+16mm Spacers. KW Coilovers. Forge DV,tip and intercooler pipes. KnN Panel Filter. Oh and the essential Re-map. GONE
  30. #29
    Essflee's Avatar
    Mar 2008
    2,007
    I personally wouldn't worry about it dragonstyle, you do get a degree of noise when you first start the car up, its common knowledge on the 1.8T lump...
    If the car settles down nicely as you say I really wouldn't be to concerned...
    revo'd
  31. #30
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Have a listen to these mate, as leggy said, its just the way 1.8t start up, don't worry about it aslong as its quietens down after a minute or two
    Couldn't find S3 engine sounds but should help you hopefully, 1.8t's have pretty much the same start and idle
    http://www.youtube.com/watch?v=2SGfVDMtqJs
    http://www.youtube.com/watch?v=Xm5td9Kf6ks
    It shouldn't sound like this, if it does then it needs help lol http://www.youtube.com/watch?v=_4IWmLD_9hs
  32. #31
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    Most people who have never heard the 1.8 20v turbo engine will be shocked when they first fire it up! It sounds like a bag of nails in comparison to alot of other engines. .
    M3's sound terrible when cold too and drive kangaroo like for the first couple of mins!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
  33. #32
    Biggied's Avatar
    Feb 2006
    Scotland
    202
    Its hard to get a good engine sound through a basic digital camera but tbh I didn't think any of the eninges sound the best in them clips, the second one sounds like the divert valve isn't working or just isn't fitted as its making a bit of an air chop noise when the throttle is closed.
    Ewan.
  34. #33
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    The turbo whistle sounds good though!!
    Mine does the diesel thing, as does my mates Octavia vRS.
    AUTOMAP
    www.eliteremaps.com
