5x100 to 5x112 hub adapters, where can I buy some???
benh999
Midlands
Hi folks does anyone know where I can get some hub adapters to convert my S3 from 5x100 to 5x112
Oh I've also noticed they range from 20,25 or 30mm which is the best width???
Ben:icon_thumright:
DPM performance do them i think, there a sponsor on here.
I got mine from venom motorsport, the size of adaptor you get depends on the offset of the wheels your getting:icon_thumright:
Little bump on an old thread. My new alloys are 5x112 so will need hub adapters. What spacer will I need with a 45 offset?
The wheels are 8J.
You can work it out.... Avus are ET32 17x7.5, RSTT are ET33 18x8... so assuming you are after an OE offset you need 12mm spacers to achieve an offset of ET33...
Add on top of that the normal 10mm front and 15mm rear spacer sizes on OE ET wheels to 'fill' the arches... you are looking at 22mm front and 27mm rear to emulate this..
In real terms this equates to 20mm and 25mm as this is whats available...
<tuffty/>
Phew, £163 penalty for picking the wrong PCD.
Might see if they do a 5x100 version :p
