Anyone! Been having a look on vagcat and the part numbers are virtual the same apart from like a letter different, the parts even look the same, would one letter mean they were a massive difference?
Did you get the arms? I have Mk.4 golf ones on mine and the passenger side blade rests on the side of the screen trim and misses a bit when I use it. I am interested in knowing if the polo arm is slightly shorter with the same pin fitting for the blade so I can solve this little problem. Only other option I have is to see if I can trim the blade down at one end.
