Chris NottSky Insurance
    Sep 2008
    Bristol
    106
    Forge split-r, 34mm ports???
    I recently purchased a forge split-r valve but the ports are 34mm, which are too big! I got it fairly cheap so was wondering if any one new if it would still work ok if i were to fit it with silicone hose adaptors?
    S3 Paul's Avatar
    Oct 2006
    2,759
    Can you list the part number?
    I wasnt aware they did these with diffrent size pipe work.
    Noggy Blue 2001 S3
    Sep 2008
    Bristol
    106
    part number is: FMBSPLTR, apparently it will work fine but will just need to but the silicone reducers for it which is a PAIN!!
    Forge's Avatar
    Jun 2003
    Gloucester
    204
    is for Evo or subaru = 34 mm all VAG = 25 mm
