JMB RetrofitsEM Tuning
    mike-turbo's Avatar
    Sep 2009
    82
    Torque setting for S3 flywheel+clutch HELP
    Hello to you all,i'm after the torque setting for the dualmass flywheel and the clutch from a audi s3 03 reg 8l .
    mike-turbo's Avatar
    Sep 2009
    82
    anybody know the torque setting?
    May 2003
    Reading
    705
    The Haynes manual for the A3 (for 1.6, 1.8 and 1.8T) says:
    Flywheel/driveplate mounting bolts
    Stage 1 60NM
    Stage 2 Angle tighten a further 90 degrees
    I'd guess the figures would be the same for the S3?
    03 Ebony black S3, Dieselgeek short shift, its started..
    Ross_S4
    Aug 2009
    Dundee
    718
    Pressure plate to dual-mass flywheel:
    M6 - 13Nm
    M7 - 20Nm
    M8 - 22Nm
    Ross_S4
    Aug 2009
    Dundee
    718
    Dual mass flywheel to /crankshaft:
    60Nm plus 90degree turn, use new bolts.
    mike-turbo's Avatar
    Sep 2009
    82
    thank you lads for that now can put the car back together.
