Badger5JMB Retrofits
Results 1 to 17 of 17
    Jul 2009
    South Wales
    37
    Porsche Brakes...
    Ive tried to do a search but can't find any infomation on the porsche cayenne 6 pot brake conversion as im planning on putting a set on my 8L S3... has anyone on here done the conversion...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    That is probably due to no one here actually doing it... 6 pots are a tad over kill I would imagine... Brembos are what most people do. I have AP's though which work just as well...
    Typical issues with using calipers from another vehicle are mounting brackets and master cylinder travel due to the capacity of the pistons on such calipers.
    Brakes aren't worth messing about with unless you know what you are doing and most people will just recommend tried and tested.
    Any particular reason for using these calipers? What rotors/discs you planning to use?
    <tuffty/>
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,574
    S3 Paul's Avatar
    Oct 2006
    2,764
    Wheel clearance will be a pain,
    Ive driven an r32 golf with the ecs big 6pot kit... its almost a double press to move that much fluid.
    Not confidence inspiring.
    The smaller caliepers from a boxster S are a good option though. not quite as fluid thirsty
    Noggy Blue 2001 S3
    Jul 2009
    South Wales
    37
    Cheers for the advice lads, has anyone got any pics of the set up on there S3 smaller caliepers from a boxster S, and can you upgrade the masterclynder off a different audi, so there wont be as much pedel travel...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,574
    Unless you want it for looks or track work, then I would just upgrade the disks and pads. If you really want Brembo brakes, then go for the Brembo GT Kit which is basically the same as the Leon Cupra R Brembo setup, with slightly different caliper design.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Or... you could try these...
    [IMG]http://i84.photobucket.com/albums/k30/tufftybloke/Random/Car/S3/Build/20090912_CRW_3616.jpgIMG]
    Calipers are AP Racing (branded TVR) 325 a pair from ebay... http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=250455042455
    Brackets, brake pipes and pads (DS2500) from Badger 5. You can run 323mm Leon discs or 2 piece stuff like mine (330mmx28mm) all of which still fit under a 17" wheel.
    Spacers maybe needed depending on the offset of your existing wheels. I have 10mm up front which clear nice on my ET33 RSTT's.
    They stop goooooood!!
    <tuffty/>
    Jan 2009
    107
    Will those TVR callipers bolt onto a 1.8T?
    Im very interested in doing the conversion if so...
    bhavin1986's Avatar
    BBP
    Mar 2008
    Leicester
    461
    Quote Originally Posted by tufftybloke View Post
    Hah, not surprised. AP racing make the brakes for many f1 teams.
    17" BBS RS Reps, JOM Coilovers, TT ARB, Facelift Front & Rear Lights, Aero wipers, LEDs all round, 6000K HIDs, Blacked out Grill & Rings, De-wipered,
    12" 1000w FliTrap Sub, Colour Coded Lowers & Skirts...
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Just done the Cayenne 6 pot conversion on my RS4 yesterday.
    Check out the pics in the B6 A4 Forum/Thread...
    1998 S4 Widebody Saloon Track Car
    2006 320d SE Touring - Ze Fuhrer's Wagon
    2001 B5 RS4 510bhp & 508ft lbs SOLD
    1.9TDI (130) Sport -Black-Revo - Mrs Stoakseya4's mota - SOLD
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    Quote Originally Posted by ScottSummerhayes View Post
    Assuming you mean A3/S3 1.8t then yes... The brackets Bill does fit these no probs...
    <tuffty/>
    Sep 2009
    34
    couldnt tell you how their fitted mate but iv got motive big brake conversion on mines and can confirm that they are unbelievable stopping power no hassle with pedal travel or anything else, only thing i will say is you need 18 inch wheels and 20mill spacers to clear calipers, ive not tried 18 inch space saver yet but conversion was done at audi so assuming it clears also make sure you use racing fluid best brakes ive ever tried amazing. Good luck with watever you fit
    Sep 2009
    worcester
    1,097
    ive got the porsche cayenne brake conversion on my s3, cant tell you much about the work involved as i bought the car with them fitted, they have awesome stopping power and look stunning, ive got 19" rims on my car, wanted to downsize to 18s to save a bit on tyres but im not sure if 18s would clear the calipers
    i would say unless you got failry big power theres no need for huge stoppers, after all if you can accelerate quickly youl want to stop just as quickly
    Oct 2009
    essex
    23
    i have porsche 996 fronts (4 pots) with 330mm disks i can put you in touch with a someone who knows everything about porsche brembos to vag cars he has everything custom made. and he is not that expensive, pm me if you want his number he is on uk-mivs.net.
    Jul 2009
    South Wales
    37
    Quote Originally Posted by tonyjohnson View Post
    Would be able to get some pics of the set up on ur car, what is the brake pedel like on yours is there a lot of travel...
    Oct 2009
    essex
    23
    i can do at the weekend its in the bodyshop at the moment, i know its not much help. The 996 fronts are the maximum you can run on your master cylinder. The s4 master cylinder can take brembos front an rear i believe but i am not sure if they can be swapped about, if you wanted bigger than 996 fronts.
    I can give you the number of my contact theres not a single thing he does not know about putting porsche brakes on vag cars.
    Jun 2007
    446
    set of porsche brakes on the tt forum for sale. decent price
