Chris NottSky Insurance
Results 1 to 14 of 14
    ben4866's Avatar
    Oct 2009
    Keighley, West Yorkshire
    32
    Rich under load, lean at idle ?
    Looking for second opinions, my AGU is running rich under load and lean at idle according to vag com. It seems to lack torque at low rpm until above 3k and fuel consumption is poor even when driving steady.
    Any ideas ?
    Thanks.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    AFM or Lambda would be my first guesses, more AFM though... it doesn't normally produce VAG COM fault codes either.
    At least it's running rich when the loud pedal is pressed, lean being the enemy!!
    Homer Simpson
    RIP S3dave
    May 2004
    nr Glos
    7,139
    your judging this thru vagcom on a narrow band lambda?
    which block are you using?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    ben4866's Avatar
    Oct 2009
    32
    Yes vag com and narrow band, can't remember which block it was but I followed Rosstech guide to fuel trims.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    narrow band is not accurate for judging afr as you are trying to do
    bill@badger5.co.uk
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Bill, have you got a wide band lambda for this sort of testing? I wouldn't knowing how my fuelling is doing...
    Homer Simpson
    ben4866's Avatar
    Oct 2009
    32
    Ah ok thanks for your input.
    I did notice today however that at idle the engine seems to rev up and down, you can hear the tone goin up and down constantly. Ive done a throttle body clean and alignment with vag com. Oh and I'm getting roughly 23-24 to the gallon driving steady ?
    I appreciate your help.
    djb83's Avatar
    redline responsibly
    Sep 2009
    north lanarkshire scotland
    68
    Quote Originally Posted by ben4866 View Post
    thats lucky 23-24mpg mines hasn't been above 22 mpg and ive had the car about 7 months now
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Bloody hell, mine is running more boost than it's meant to on a Stage 1 map and a fair wack of other mods and I'm getting a 27 average and that caning it a fair bit since I've got a lead right foot...
    Am I just lucky?
    Homer Simpson
    ben4866's Avatar
    Oct 2009
    32
    WOW ! Either my bog standard AGU isn't running correctly or you are lucky !
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    As Terry Tibbs would say... Fack knows. Drops to 5 MPG when I give it hammer though!!
    Homer Simpson
    Oct 2009
    newcastle under lyme
    17
    22mpg !!! wow i can get mine up to mid 30s n still have fun its all about revs and keeping the momentum going .but i am a taxi driver so when I'm not in race mode i can't help driving as economical as possible ... good tips are over 2.2k is bad don't over break in corners n don't press ya clutch till stall speeds . trust me try this and your mpg will go rate up
    A3ster's Avatar
    Oct 2008
    87
    I have an AGU aswell and return around 28mpg.
    RIP S3dave
    May 2004
    nr Glos
    7,139
    yes I do, thats how I would do a narrow band car when mapping
    bill@badger5.co.uk
