Volks AutosEM Tuning
Results 1 to 15 of 15
    Soon be christmas!!!!!!!!!!
    Feb 2008
    North Wales
    163
    Cam pulley wobble!!!!
    Right then, feeling industrious I thought I'd do my cambelt and water pump. Before I started I had a look by pushing the top cover to one side and noticed a fairly significant wobble on the top pulley. Couldn't really see much but it looked as though the belt was wandering. I've now finished the job and the car is running fine but the cam shaft pulley has got a pretty big wobble on it. The bolt is tight and i can so no signs of any other problems. Will try and put some pix and a little video up.
    Has anyone come across this problem before? I'm more than a little concerned....
    Feb 2008
    North Wales
    163
    Forgot to say the belt runs nice and straight on all the other pulleys!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,521
    That is not right. I would be removing the pulley and reseating it tbh
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    and/or replacing the pulley!
    TD5 Land Rover Defender build
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Any possibility that it may be warped?
    Homer Simpson
    Feb 2008
    North Wales
    163
    I'm thinking the same but really can't be arsed after all the hassle of doing the belt! I wonder if the end of the cam is gonna be knackerd, does anyone know if it has some sort sort of woodruff key??
    Apr 2004
    12,521
    the Pulley mounts onto a pin in the end of the cam with the bolt running through the centre.
    Feb 2008
    North Wales
    163
    ta, guess it's gonna have to come off! I suppose it's not gonna be too much hassle. I wonder why it's like that? Cheers for the replys!
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    did you get access to the chain at all ?
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Feb 2008
    North Wales
    163
    nope, only done the cam belt, tensioners and water pump. Why do you ask?
    Nov 2005
    UK
    1,688
    just wondered what the chain look liked like & how the tensioner assembley works. Possible issue with mine, either that or a cam belt bearing somewhere has gone. Strangley its been doing it was a while now & no problems at all just the dreaded ticking noise it maes on turnover.
    wanted for 8L S3:
    Milltek system
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Seen this before on another make of car and it ended up been the cam that was bent due to engine damage done in the past, it was bent valves after cam belts jumped on a pulley.
    Feb 2008
    North Wales
    163
    Well it turns out the old pulley hadn't been fitted right. New one fitted and it's now running spot on, what a relief!! Thanks for everyone's input :-)
    Apr 2004
    12,521
    nice work.!!
    Feb 2008
    North Wales
    163
    just relieved it wasn't the end of the cam that was the problem! Had visions of shelling out for a new exhaust cam!!!!!
