Volks AutosChris Nott
Results 1 to 26 of 26
    Aug 2009
    Cheltenham
    335
    How Low Did You Go?? Suspension
    Hello, I am planning to lowering my ming blue S3 which is currently on the standard 17" wheels. I am looking at KW 30mm front and 25mm shock and spring set with the view to buying BBS CH 18 reps.
    Apparently H&R 25mm springs and B8 shocks is the best combo but works out a bit pricey.
    Has anyone got a photos with information on setup to give me any more ideas.
    Oct 2008
    114
    Hi I have My S3 lowered with the KW suspension kit 25/30 mm and I am having 18 inch on it.
    See picture for the results
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I have the KW Springs and weitec dampers
    The ride using this set up is very comfortable, i do like the way H+R springs make the S3 sit though
    Aug 2009
    Cheltenham
    335
    Paul S3 are they 18s in the photos looks OEM but not??
    Aug 2009
    Cheltenham
    335
    Sandip how much did yours? F-30 R-25? do you think it is noticable differerence compared to the H&R -25mm?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Yep, mines 30fr 25rr, the KW's tend to make the rear squat a little which i quite like, the H+R look more evenly lowered, with the right offset though you can get both the KW and the H+R's looking nice, CH's will look nice with which ever you choose. The H+R - B8 combo is very good but pricey, the KW's are good allround
    Aug 2009
    Cheltenham
    335
    Thanks sandip, has anyone got H&R setup??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Apex 30mm + B8's on mine... will post a pic once I get some daylight and washed her of course
    I had Eibach Pro (25mm F 20mm R) and didn't like the way she sat on them but the ride was spot on. Got some Apex 30mm and the ride height is spot on but make the front a tad crashy on crappier roads. Still rides real nice though when there isn't pot hole...
    <tuffty/>
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by Barks View Post
    This is the H&R/Bilstein set-up:
    A few things to consider:
    If you are changing springs and dampers, and go -20mm or lower, you run the risk of scuffing your sump. That's with stiffer dampers...mine was scuffed.
    Change the springs only, and stick to worn, poor, Audi dampers and you risk doing more that just scuffing your sump.
    By -30mm, on standard dampers, I'd say it's a very real risk of smashing the sump...so be aware of that.
    Also, if you lower even 20mm, you should budget for adjustable tie-bars at the rear.
    You can do without...and get WAY too much rear negative camber which gives huge inner edge tyre wear and unpredictable handling...
    Or you can fit them, adjust them properly, and suffer no adverse rear tyre wear, get better handling - more predictable - as well as far better drive and much more confidence.
    Just something else to consider...and add to the cost!
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    I've had my KW's -25rr on for a few tyre/alloy changes and i've had no uneven tyre wear at the rear and it handles well, i've had it aligned twice as i was getting inner tyre wear on the front. I say get it lowered, if you start experiencing inner wear at the rear get tie bars as Essthree has advised, i totally respect Essthree's post, just passing my experience on
    Found this too on the 8L pics thread, bbs ch's and H+R
    Aug 2009
    Cheltenham
    335
    Ess_three The adjustable tie bar was one of those things on the bottom of my wish list (not very interesting) it might have to edge up the list mmm. I definitely plan to change the dampers at the same time, maybe a homemade ally sump guard is in order as the plastic one is missing and there seems to be excess of speed ramps around gloucetershire.
    Thanks everyone for the photos and info, any more welcome!
    Aug 2009
    Cheltenham
    335
    Quote Originally Posted by sandip View Post
    Nice photo, KW shocks and springs seems like it would be worth ago for the sub 400 spend, that will leave more pennies for some decent tyres. Cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Sadly these go hand in hand with dropping a Quattro (S3 or A3) but worth doing... The B8+H&R-25mm+tie bars is a tried and tested combo... you will NOT be disappointed having splashed the extra on these... best thing I ever did for mine...
    Haven't they just... We got those sump busting individual lane things up in where I live... I have to go into the middle of the road to feel safe enough to get over them. Not that Gloucestershire roads are any good anyway... Cheltenham roads are complete rubbish!!!
    <tuffty/>
    Oct 2008
    114
    BArks, thay are the 18 inch S4 replica's.
    On the 4th picture you see they are a bit sharper than the S3 wheels.
    There are more here on the forum having the S4 reps
    LordNelson's Avatar
    Aug 2009
    167
    Sandip.....I do love the Noggy blue and Black combo you have going on.....looks awesome
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
    Jun 2009
    41
    DECT IT!
    JS1500's Avatar
    Howdy
    Sep 2009
    Granite house, Granite City.
    1,167
    Paul S3 - how's the ride on the KWs?
    That's how i'd like mine to look, but I still want a decent ride (lots of potholes around here!).
    Cheers!
    2001 Audi RS4 2.7 Bi-Turbo - Nogaro Blue
    1975 MG Midget 1500 - Tahiti Blue
    2003 Audi S3 - Dolphin Grey; SOLD!
    Oct 2008
    114
    Kw rides perfect. It is stiffer than original, but not to stif. I am using the car as my daily and that's no problem at all. Here in Holland they are fond of traffic bumps etc and i have no problems with them.
    wheels are standing nice, front and back equal en handling is great. I cannot give you any negative things about this setup.
    I think it is low enough because I am not a fan of the too much lowered look. Wheels are perfect in the arches right now and that is wat I was looking for.
    Works 60% the time, Everytime.
    Jul 2008
    Up North
    1,577
    Quote Originally Posted by Ess_Three View Post
    Tis a nice level. Got myself some B8's and H&R's too. Just need to get hold of the tie bars and arbs but not it a rush as wont fit them untill later next year.
    Wheels look good. Need to get mine sorted as I curbed one of them . Thinking maybe polished to match the mirrors.
    2003 Audi S3 + Go faster bits
    Aug 2009
    Cheltenham
    335
    Thanks to everyone for the information. The final question do you spend 385 for the KW matched set of springs and shocks or 750 for the B8 and H&R. There is not much between them in looks, but is the ride that much better???
    Olly P's Avatar
    My other cars a mk2 Golf GTi
    Dec 2008
    Oxford
    686
    Or the B8's and KW springs!
    Nov 2008
    95
    My S3 is pretty low on FK coilovers with shortend front droplinks, dont have any problem with sump or anything, and I live in devon, lots of lanes.
    Oct 2009
    63
    so could you put eibach 50mm kit on a 06 a3 sline
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,298
    The most popular choice is the H&R springs with the Bilstein B8's but for value for money the KW kit is a really good option and as said gives a great stance. Also think about adjustable rear tie bars when lowering the S3 8L's.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Aug 2009
    Cheltenham
    335
    DPM, Just had a KW kit delivered to my door from you guys! Nice and clean
    Jun 2009
    41
    70mm on front and 40 on back.... jom coilovers :D
    a3 not s3
