AH FabricationsEM Tuning
    Mar 2009
    21
    Cruise Control not working?
    Morning Guys/Girls...
    Just a quick query, i recently had my clutch pedal replaced, and now my cruise control isn't working... Any connection between the two?
    Also was thinking it could be a fuse or something?.. ANyone know where the fuse for this is?
    Thanks in advance Guys!!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,557
    Clutch switch not connected or not working? CC uses this so if this is open circuit then the CC won't work.
    <tuffty/>
    Nov 2008
    95
    mine didnt work, till i changed the clutch switch, was about 8 from audi, then it worked perfect
    Mar 2009
    21
    Spot on cheers guys, is it easy to get to if i just poke my head under there?!
    Ross_S4
    Aug 2009
    Dundee
    718
    Your clutch switch probably hasn;t been adjusted after the new pedal fitted.
    you can get the switch out which should be push in and turn to release it if you stick your head under the dash.
    there is a plunger on the switch, pull this out the way and you should hear a few clicks. DON'T PULL TOO HARD! just enough so it comes out a few clicks.
    Then stick it back in which again should be push in then turn and release.
    If you then push your clutch pedal fully down and then rtelease it, try your CC after this.
    If it doesn't work then your switch may be knackered.
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    They're 12!
    Careful if you don't snap the plunger as they're onlt plastic!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
