AH FabricationsSky Insurance
Results 1 to 18 of 18
    lloydsta101's Avatar
    Bristol
    134
    'Vacuum' type noise on start up.
    Hi there,
    Over the last few weeks I've been getting what can only be described as a 'Vacuum' type noise when starting up. This only happens a couple of times a day, usually when the car has been left for 4-5 hours. The odd thing is that it doesn't always do it on a morning, but nearly always does when I drive home for lunch and then again after work.
    It's quite a loud noise... like someone is literally standing next to the car with a vacuum, lol. If I leave the car running on the spot once started, the noise will continue for about 2 minutes. Although, if I drive away and give it a few high revs then the noise goes after about 5-10 seconds.
    Does anybody know what this is, as it's starting to bug a bit now?
    Cheers in advance guys!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Secondary air injection pump. used on cold starts to inject air into the system to aid warm up of the Cat.
    Its probably leaking as they are made with silly little rivets that split away
    Bristol
    134
    Thanks for the quick reply!
    Is that a hard thing to fix/change? Could I do it myself, or is it a garage job?
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Mines been doing the same, where abouts is this secondary air injection?
    djb83's Avatar
    redline responsibly
    Sep 2009
    north lanarkshire scotland
    68
    same problem i have priced a secondary air pump was about 400 and the combi valve for it is around 80 so its costly to say the least prices were from verve in wishaw scotland
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    bloody hell 400!! Is it possible to bypass this pump in anyway or repair it?
    djb83's Avatar
    redline responsibly
    Sep 2009
    68
    i know still working out if it is the pump i think ill change the combi valve 1st to see if that cures it lol
    Sep 2008
    Bristol
    106
    Its the air pump to heat the cat, is a really easy repair! search it, there is a how to guide which i followed and its cured the problem. its the seal around the casing which needs bolting together.
    Bristol
    134
    I've read somewhere that it's because the standard secondary air injection pump has rivets on it or something, so you need to possibly drill them out and replace them with nuts and bolts.
    Sounds easy enough, but would be much simpler if I knew what it actually is and where to find it.
    djb83's Avatar
    redline responsibly
    Sep 2009
    68
    try this thread http://uk-mkivs.net/forums/p/141240/940861.aspx#940861 i'll be trying this on my days off just did some searching and found it
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    location location
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    thanks for that djb83! i'll be investigating that asap!
    Bristol
    134
    Found the guide, hope this helps you all:
    Ross_S4
    Aug 2009
    Dundee
    718
    Check the hoses for the secondary air before stripping anything though, should be one from the filtered side of the airbox down to the pump then another back up to the combi valve.
    Thay are about an inch diameter and corrugated plastic.
    These just have a clip connector which {should} have an o-ring in it too.
    Haglos's Avatar
    jabba mapped
    Mar 2008
    242
    i done this proces on mine last week and it still makes that irratating noise and i dont want to source a new one for that price as it useless and the facelift s3 dont have it
    The Doctor's Avatar
    Jul 2009
    Planet Earth
    1,197
    Why don't facelift S3s have it then?
    Apr 2004
    12,523
    they do dont they? in front of the engine under the Inlet manifold
    Facelift TQS deffo does
    27,121
    Its definitely secondary air pump, could have got water in aswell which makes them bloody noisy, had 2 swapped on my s3.
    yeap facelifts as we confirmed before Mark have them, show in etka
