Hi Folks,
Been trying to get to grips with the Climate Control on my 2002 S3. The one thing that's baffling me is that no matter which setting I use to select which vents I want air to come from I always get air blowing into the footwells (lower vents according to the manual).
I've tried selecting only the windscreen then also tried just the upper vents using the buttons on the right hand side but to no avail [img]/ubbthreads/images/graemlins/confused.gif[/img]
Is this normal or should I be able to individually select the vents required ?
I will mention that Audi did previously replace the CD/radio head unit for a previous owner so I'm guessing they may have made a boo boo when putting it all back in. It's still under warranty so if there is a problem I would expect they would fix it.
TIA [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
