Hi guys,
Since I've had the car the horn hasn't worked and as I've found out driving without one is very dangerous as I seem to attract all the idiots on the road not abiding by the highway code.
Ive checked the horns by giving them a 12v power supply and both of them work, Ive checked the fuse and that is intact, Ive also swapped the horn relay for a working one and the horn still doesn't work.
I then bridged two of the terminals on the relay and the Horn armed, so I have narrowed the problem down to being between the steering wheel and the fusebox.
There is no voltage at any of the connectors at the steering wheel which is making me think that my airbag is not functioning? However there are no airbag warning lights that display on the clocks.
This is the fault code which shown up on VAG COM:
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 06435
1 Fault Found:
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
Any idea on what the problem could be? Anyone have some wiring diagrams I could follow up?
finally I also noticed these connectors behind the steering wheel which were not connected to anything, any idea what they are for?
Many thanks
Coding: 15178
Shop #: WSC 06435
1 Fault Found:
Many thanks
