Chris NottMonster Motorsport
Results 1 to 12 of 12
    Jun 2007
    614
    Adaption with VAG-COM
    Would anyone have details on how to carry out adaption using VAG-COM?
    I understand that the ECU "learns" certain values over time, and with adaption it is possible to reset these values so that the ECU can "learn" them again.
    I recently got a remap, and it was suggested that carrying out adapation with VAG-COM would be a good idea.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    I dont know about doing it using VAGCOM but I'm sure disconnecting the battery for an hour has the same effect.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jun 2007
    614
    Ok, thanks. I'm pretty sure I heard somewhere that it can be done with VAG-COM. Anyone any info on this?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Just read your codes and clear them that can reset, or adaption 10 , channel 00 read, save.
    Westy's Avatar
    Dec 2008
    17,156
    Mark. He's talking about putting the ECU back into learn mode.
    S3 Build Thread
    Apr 2004
    12,354
    That will reset the ECU to defaults mate. Says all reset to factory defaults afterwards
    Jun 2007
    614
    Quote Originally Posted by Byzan A4 View Post
    Why would reading your codes and clearing them reset everything that the ECU learns?
    There is no module 10 (or named Adaption) available in the version of VAG-COM that I have...
    Apr 2004
    12,354
    sorry its engine, then adaption, then read save.
    And reading the codes and reseting them puts the ECU back into to learn mode, don't know why but it does
    Jun 2007
    614
    Thanks, I'll give that a go later!
    26,721
    what version you using then?
    Feb 2007
    UK
    229
    Byzan A4 is corrrect. clearing the fault code, even if there aren't any, will reset your fuel adaption values. You can see this by viewing block 032 = Fuel adaption values, it will read zero once you do the "clear codes".
    Apr 2004
    12,354
    You can read codes no problems without resetting anything so do not worry about that. It's a little known feature
