EM TuningJMB Retrofits
Results 1 to 7 of 7
    Aug 2009
    Wiltshire
    21
    Change headlamp bulbs??? Tell me I can, please?
    I can't find a guide anywhere for this.
    Is it possible to change the headlamp bulbs on an 03 A3 without taking it apart? The gap behind the lamp looks pretty small and there are several exposed wires. Last time I did this on a car it was a 'twist and pull' thing.
    Trying not to go to a mechanic for this!
    '03 A3 1.8T Quattro Sport
    Sep 2005
    uk
    80
    most bulbs can be changed without too much problems, other than losing skin from your knuckles... which bulbs do u want to change?
    Aug 2009
    Wiltshire
    21
    Quote Originally Posted by 08080808 View Post
    I want to change the main beam and dipped beam.
    Sep 2005
    uk
    80
    i have heard of people doing it without taking off the bumper, but you will need small hands. also if you arent sure how the bulbs release and lock, there is the chance of scratching or cracking a bulb. but once the cover is off, if your dont have xenons then they are held in by metal wires (like a coat hanger) and they are just hooked on. once you see how they are held in it is easy to release them. take alook behind the headlight and it will make abit more sense!
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    It can be done without removing the bumper but it is very tight. I ended up taking out the battery when i changed mine to get more room.
    GeneralWest's Avatar
    Sep 2009
    Cambridgeshire
    168
    I changed mine the other day, it's possible but but a bit fiddly due to lack of room. The only real problem was not being able to completly remove the plastic covers on the back of the lights due to the connector for the xenon's sticking out quite far. If you don't have xenon's it's probably much easier. Mines a pre-facelift but I wouldn't have thought it makes much difference. Just be carefull not to damage the headlight or bulbs. You'll probably lose some skin but that's all part of the fun!
    Aug 2009
    Wiltshire
    21
    Batteries I can deal with.
    Skin I can afford to lose.
    As a backup, a local Audi garage as agree to do them for 30 minutes labour.
    Thanks for the info - I'll give it a go I reckon.
