Sky InsuranceAH Fabrications
Thread: POLISHING
    imported_velcrobix
    POLISHING
    im about to give my s3 a polish with autoglym high resigh polish. is it best to use my electric polisher to apply the polish of just to buff the polish off??
    imported_velcrobix
    Re: POLISHING
    i need to cut it back a little in order to remove some of the scratches though??
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: POLISHING
    I guess it would work, but I wouldn't want to introduce any of those circular swirls.
    Just going by wnat I've been told in the past. I always apply polish in long strokes and use a circular motion for the wax.
    I could be wrong of course.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    563
    Re: POLISHING
    Depends whether it is a high speed polisher or a low speed polisher.
    Rai
    Apr 2003
    17
    Re: POLISHING
    if its a random orbital you will be fine esp. since i'm guessing that autoglym stuff is more of a scratch filling rather than cutting polish. let the weight of the buffer and the product do its work - don't apply pressure.
    buff off by hand and note you should never use a circular motion as any micro marring will be visable from all angles. using a back and forward motion following the wind-flow patterns over the car.
    go see autopia.org for good detailing forums and how to's.
