Chris NottEM Tuning
Results 1 to 9 of 9
    imported_prawnie5217
    S3 revs not dropping!!!!
    For the last couple of weeks I have noticed that the revs on my girlfriends S3 do not drop instantly when you put your foot on the clutch!!!!
    Any ideas what the problem could be???
    I have recently had to replace the clutch pedal and associated switch on the pedal housing, could this have caused the problem?????
    Re: S3 revs not dropping!!!!
    wondered if it could be a stuck dump valve??
    UK
    289
    Try a search for more detail, as this has been asked previously, but the short story is its actually quite 'normal'
    Dunc
    Feb 2004
    331
    As dunc says.. something to do with the ECU detecting that your accelerating hard and maintaining the revs in accordance.. personally I hated it ..
    nervus's Avatar
    Apr 2004
    1,116
    eh? Why would the engine's RPM drop when you press the clutch?
    Do you mean when you take your foot off the accelarator?
    imported_MattT
    Yeah im not a big fan of it and yes it is the same on other new VAG cars.
    Would a lightened flywheel really fix that?
    Rai
    Apr 2003
    17
    it sounds like the clutch switch not working again.
    does this happen while idling in neutral... you raise the revs and they take forever to fall? if it does try pulling the accelerator pedal up with your hand and seeing if the revs drop. that was the problem i had and needed a new throttle pedal assy. to fix it (when the car got heat soaked the pedal would not fully return... maybe by 1mm) .
    imported_SYNAPS3
    YES! ABSOLUTELY!
    It must be the clutch switch.
    I had the same problem. Extremely annoying. Not only the car but also some dealerships who claimed that it was normal. Also got alot of the heavy flywheel crap... But if it was NOT there before it cant suddenly appear. Eventually got a new and even more faulty switch and with the service manager sitting in my car with me, the cause of the problem was evident. Got a new switch and my Rev's drop nicely now. Change the clutch switch cause you will not regret it! <font color="blue"> </font>
    SYNAPS3 - Just add MDMA
    By The Hole in the Wall, Kent, U. K. (The 1st Hole in the Wall not the International one!)
    123
    It possibly is the potentiometer, (fly by wire gizmo on the throttle body). Frequently happens on the Peugeot 206 cup cars that we use at the rally school.
