Chris NottSky Insurance
Results 1 to 16 of 16
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    Oh noes... Manual Boost Controller.
    Hi Everyone,
    Just looking for a little help and advice if you'd be so kind!
    I've been having a poke around under the bonnet of my 1.8t AGU and have seen that the plonker who owned the car before me has fitted a manual boost controller, I've done a search on the forums and found that this is a bit of a bad idea for various reasons.
    I'm just wondering what the mbc will have replaced? Is it the n75? If so where is the best place to get one from and which 'letter' should I get as I hear there are loads of different n75's.
    Look forward to hearing your thoughts.
    RIP S3dave
    May 2004
    nr Glos
    7,195
    mbc does replace the n75 yes.. do you have any check lights on the dash? chances are hopefully its electrically plugged in somewhere but not connected vac pipe.
    get the std valve for your model is my advise. later J valves can spike, which may or may not be what you want
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    Thank you for the response, Bill.
    I don't have any lights on the dash and the car seems fine but I heard there is a chance it will damage my engine to have this fitted in the long run.
    Would the best place to get this from be an Audi dealership? If so could someone please provide a part number?
    Also, I have heard about the n75j, I am not really interested in increasing the performance, I just don't want to do any damage to my beautiful, beautiful car. Does anyone know which letter/revision n75 should go on an AGU engine?
    Thanks all
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Quote Originally Posted by Mings View Post
    Thanks all
    so long as its not running excessive boost over std (without the fueling and ign timing to go with it) it could well be fine.
    do you know what boost it runs? 7psi ish is about std level, remapped is double this
    www.badger5.biz
    bill@badger5.co.uk
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    I don't have a boost guage and the controller itself is pretty non-descript, counter-clockwise for less boost, clockwise for more boost supposedly.
    What symptoms or problems could I expect to encounter if there was too much boost?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    I would have thought that your car would go into limp mode if you were pushing too much boost by a non electrical valve. You'd get a dash light come up and your car wouldn't run properly.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    So there's no risk of me damaging the car with the boost controller set how it is now then? (It's been at the same level since I got it in January and I've not once seen a dash light come on (cept handbrake, petrol and lights :P ))
    Thanks for the advice so far, good for the ol' peace of mind
    Westy's Avatar
    Dec 2008
    17,283
    The ECU should intervene if it thinks the boost is too high and will protect you engine by putting your car into limp mode. You have nothing to worry about mate.
    S3 Build Thread
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Westle: presuming the non map sensor equipped car even has a clue what boost its running??
    AGU is'nt it? (correct me if not please)
    more boost without the fueling to go with it is risking lean running, which is melted pistons and burnt valves
    www.badger5.biz
    bill@badger5.co.uk
    ash_pearce's Avatar
    Feb 2009
    Leicester
    319
    I run a 'J' valve on mine with no issues. No increase in boost pressure just seems to hold it longer. I've done lots of vagcom readings to check fueling all's ok for now...
    To be honest though i'd ran out of cash after my rebuild and the j valve was loads cheaper otherwise i would have stuck with the standard n75.
    A1 Competition line 1.6 tdi
    A3 1.8T Sport
    Mar 2009
    Plymouth
    77
    I think I'm going to grab myself an N75 just to be safe. I'm pretty sure my engine is AGU but I'll check again tonight just to be sure.
    I'm presuming the best place to get an N75 is the Audi garage? How much do they generally cost and does anyone have the part number please?!
    Thanks for all the help and advice so far!
    Sep 2009
    worcester
    1,097
    just to muscle in on this topic, the problems that can occur through having a mbc fitted described by westle, sound exactly like the problem im having with my bt s3 (epc light comes on and in limp mode) and i have an mbc fitted, ive checked and its still connected electrically
    should i swap the mbc out for an n75 valve of some description?
    i need to find out what engine i have exactly, where can i find the engine code? (now ive asked its gonna be somewhere really obvious lol)
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,472
    I also have a MBC fitted with the N75J still connected with no lights and seams to run fine.
    Running 15psi on a S3
    RIP S3dave
    May 2004
    nr Glos
    7,195
    Quote Originally Posted by jonny87 View Post
    boost deviation code thrown?
    www.badger5.biz
    bill@badger5.co.uk
    Sep 2009
    worcester
    1,097
    ok guys ive taken some pics of the setup on my car, as i got nothing to compare it to hopefully someone will be bale to shed some light on the situation, so here we go:
    also i just checked my engine code its an auy, dunno if this is helpful or not lol
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    it looks to me like you have your n75 valve still there, and for some reason they have put a mbc in too for good measure (n75 is the second pic) so you need a straight piece to replace the mbc and join the pipes together
    hth dave
