Volks AutosChris Nott
Results 1 to 14 of 14
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    Help head in pieces!
    was doing 110 on my private road last week when my timing belt decided to pass on to the after life, unfortunately it cracked the head in 2 and made a mess of 2 pistons.
    which 20v T engines can i scavange a head out of as ebay is asking for 450 for a head with valves!
    or even better does anyone have a head going spare?
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    God i'd love to see where everyone find's all these private roads
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    its an s3 by the way, AMK engine
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,848
    Head/Engine off an S3(8L)/TT(225)/Mk1 Leon Cupra R is what you are after.
    You've got to have a laugh!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    If you have an AMK engine then it will be VVT. Any small port 20v head should be OK and you can transfer your VVT controller etc over if it doesn't have one. Be wary as breakers may try and charge a premium for an 'S' head over a normal 20v one when they are technically the same thing.
    <tuffty/>
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    found this http://cgi.ebay.co.uk/ws/eBayISAPI.d...tchlink:top:en
    says its a small port version but a friend i spoke to said that only the 210/225 bhp models of the vag range will fit and this says its off a mk 4 golf, would only be a 150bhp wouldnt it?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    TBH if you are never going to run any big power through it, any 20V turbo head will suffice, as there are 2 castings on the main head, small port( which you have) and large port. Now whilst technically the flow through the inlet will be disrupted due to slight differences in ports if you used a large port version on a normal tune i would not expect anyone to notice.
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    can anyone acctualy confirm this for me because fixing up my engines turning to be very expensive as it is without buying the wrong head, fitting it and then it not working. my friend i spoke to is a Vag tuner and said only to use the 210/225 engines, it would help me alot if this was untrue but i really need a definite answer
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Like said, any 20v turbo head should fit, there's a guy on the sc.net forum who bought a BAM engined LCR that had a APU head fitted, he didnt even know, running perfect for over 18 month.
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    so will the one in the link fit? i will be looking at a hybrid turbo so need the engine running as sweet as poss, thanks for your help
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I'd stick to an AMK head.
    I would have thought an AMK or BAM head are swappable...but to be sure, just stick to an AMK head.
    Badger Bill would know i'm sure...he'll probably know off the top of his head which heads are compatible.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,944
    almost any smallport head will fit... just check egr drilling is there on yours vs the ones you look at. swap cams and tensioner/vvt etc
    I have a smallport head here which you can come look at to compare etc.
    bring your cracked one with you. it should be compatible
    bell me on 07976 800775 if you want to pop round and see or discuss etc
    regards
    bill
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,025
    If its an AMK, its the same as mine
    <tuffty/>
    dela's Avatar
    Apr 2008
    Gloucestershire
    260
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    it is AMK, do you have one spare?
