JMB RetrofitsBadger5
Results 1 to 16 of 16
Thread: VAG COM Error
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    VAG COM Error
    Last post today I promise!
    Getting this error:
    00575 - Intake Manifold Pressure - 08-10 - Control Limit Surpassed - Intermittent
    Quite common on Diesels it seems, but can't find anything useful about it on a 1.8T. Oddly, it's and AGU which doesn't have a MAP sensor?
    Any ideas - because I'm going to drive this car off of a f**kin cliff soon....
    GRRRRRR!
    Homer Simpson
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by tufftybloke View Post
    Hey mate, is the conversion done yet?
    I've seen this on the Wiki, but I'm confused as to how it knows the pressure is too great based on the fact there is no pressure sensor!
    Homer Simpson
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    Airflow x load x throttle position are all taken into acount to work it out. It's usually a side effect of a chip/flash
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Ok, thats good to know. Having a problem with ym AGU TB (I think) as on VAGCOM it only ever says 'Part Throttle' despite being WOT. Angle reported is 85.1. I've taken it off, cleaned it, put it back on and re-aligned it also. Still only ever says 'Part Throttle'.
    Update - car is also misfiring. Not sure on what cyl, but misfires in neutral just revving engine between 5000 - 5500. Sounds like the rev limiter (but isn't - obviously). Any ideas? Still seems to do it with the MAF disconnected.
    Homer Simpson
    27,129
    Surely if you have had a reported issue with your TB & you now have misfires it would point to the TB being at fault, which could possibly cause mixture issues no, thus misfiring possibly.
    In my head, if you've realigned & it still is giving you hassle then I would hazard a guess its faulty & a replacement would be advisable, atm it would point to this as a possible reason anyway.
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Hi mate, not sure I've made this 100% clear. I've not got any VAG COM errors reported regarding the TB at all.
    Got an 00575 which is Intake Manifold Pressure Control Limit Surpassed. Unless that directly points to the TB?? TB works fine, i'm just interested to know if an AGU will ever report 'WOT' or just 'Part Throttle' on Block 098.
    My fault for putting 2 issues in 1 thread, however I feel they may be related if Intake Mani Pressure is worked out with TB angle....
    I wish I had a mate with a AGU TB to test, a new one will cost about ten million quid.
    Homer Simpson
    May 2010
    Hi!
    Were you able to resolve this?
    I'm have the EXACT same issue with the Pressure error, and not showing WOT in the block 98.
    Thanks!
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Wow, a blast from the past here! I miss that A3, once all the problems were ironed out it was great fun!
    OK. First question - is your engine standard? Mapped etc?
    Homer Simpson
    May 2010
    It's an AGU, but with S3 stuff on it.
    Brute rods, and I'm boosting 1.5bar with an MBC. The ECU was "touched" but not perfect.
    This was running fine up until last month or so.
    From what I've been reading now, it could be the MAF...
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Yes, it could well be the MAF.
    My problem was different in that it always did it, where as yours has been OK and started doing it.
    If I were you, I would see what your air flow is doing by logging block 002 on VAG COM.
    At that boost with a K04, you should be expecting to see somewhere around the 200 g/s mark, if not more.
    The lack of MAP sensor on the AGU means that intake mani pressure is calculated via TB angle and air flow. A dodgy MAF will therefore throw a spanner directly into the works.
    Homer Simpson
    May 2010
    I'll check the MAF, maybe clean it, and do some vagcom logs.
    As I have a 3" MAF housing, I should see around 140/160 g/s.
    I'll report back
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Quote Originally Posted by hidro View Post
    I'll report back
    You should be seeing more than that mate really, depending on what S3 bits you have, and more importantly, what turbo.
    On my old AGU K03S which is the car this post was originally about, I used to see 175 G/S, and Prawn who also has the same setup but with a better map, used to see over 180 g/s.
    160 g/s is 200 bhp.... unless that's what your expecting to see? Depends on your current config I guess.
    Homer Simpson
    May 2010
    Yeah.
    The stock 2.5" MAF housing would "produce" a higher number, and could get to the point of hitting the maximum the ECU can read.
    So, with the 3"MAF housing, the number will be lower, and gasoline will be adequeate.
    I have the S3 turbo, injectors, TIP, MAF housing.
    234bhp at 0.9bar
    Welly's Avatar
    VX220 SC Driver :)
    Aug 2009
    Gloucestershire
    10,695
    Have you got this engine mapped for the mods?
    Or are you just allowing the ECU to calculate the fuelling based on the airflow and lambda readings on say a Stage 1 map?
    Homer Simpson
    May 2010
    Yes, I do have this mapped, but I know it's not perfect. I have way too much fuel (10.5 @ redline), and this was working fine.
    I believe I might have resolve it.
    I tested the MAF readings, and I can see the normal numbers, so it's not from there.
    I then tested a N75 I have, and I did not see the error again. I can only think that the N75 that was there is fubar, even though the N75 is not being used in the system. It's just there so it doesn't throw a code.
    Another thing is that the baro sensor was laying around, so it could also be that.
    The good thing is that the error is not present at the moment. :D
