Volks AutosAH Fabrications
Results 1 to 11 of 11
    Jun 2006
    Surrey
    25
    Aluminium Spacer On Suspension
    Hi guys,
    I have some bilstein B8s and some H&R springs and will be looking to fit them in the next couple of days.
    For the front dampers and springs I have ordered from audi:
    - Spring Disc
    - Aluminium Spacer 'Distance Piece'
    - Threaded Bush
    - Bearing
    - Strut Storage
    I have had a look at a couple of MKIV Golf guides and they say not to bother with the aluminium spacer - for those of you who have replaced your suspension did you use it or leave it out?
    Jun 2006
    Surrey
    25
    Here are a couple of pictures:
    First one without the aluminium spacer and the second one with the spacer
    To me it looks too big but is it needed?
    Sep 2009
    26
    pics not working ?
    Jun 2006
    Surrey
    25
    Sorry have updated the links!
    S3 Paul's Avatar
    Oct 2006
    2,764
    I dont think my car had those fitted.
    But im not 100% sure. it was 2 year ago now
    Noggy Blue 2001 S3
    Jun 2006
    Surrey
    25
    Cheers - anyone else do the same?
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    Without the spacer it looks very close to the end of the threads.
    .. may possibly prevent the bush from fully collapsing.
    however without it, it should sit a few mm lower
    Jun 2006
    Surrey
    25
    Yes your right without the spacer the top bearing is sitting on the end of the thread - the only other thing I can think of is to get a slimmer spacer?
    LordNelson's Avatar
    Aug 2009
    167
    i have just replaced the bearings and the top mounts on my 2000 S3 APY and there was no spacer there....this is the first time ive seen one there actually. (i have changed the top mounts on Bora's and Golfs before).
    Im sure that with the spacer on, you would struggle to get enough thread through the top of the housing to fasten the retaining plate/nut on.
    2000 Audi S3
    1967 VW Beetle
    Where Do I go From Here?
    Aug 2004
    526
    Another tip - don't fit those dumbbells as it will ruin the handling.
    Jun 2006
    Surrey
    25
    Haha Today I fitted them without the spacer i saw that the old shocks didnt have one fitted but it showed up on ETOS originally so thats why I ordered them!
