Badger5Chris Nott
Results 1 to 10 of 10
    imported_20VT
    210hp S3 stock boost
    Any know what the stock boost on a 210hp S3 is ? VAGCOM logs of group 115 would be nice [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,536
    Re: 210hp S3 stock boost
    Max boost on an S3 210 is 1 bar
    imported_20VT
    I logged group 115 using VAGCOM and it showed around 1800 mbar - are you sure its 1 bar ?
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    [ QUOTE ]
    [/ QUOTE ]
    Vagcome logs atmospheric pressure. If it states 1800mbar, then its actually 800mbar of boost.
    Rich
    Sep 2003
    Manchester
    340
    [ QUOTE ]
    jimboA3 said:
    [ QUOTE ]
    pure said:
    There is an equation that can be used to convert mbar to PSI. Chipped I run/spike to about 24psi, but average about 20-22psi.
    Not sure about stock. But I think that is about 1.4Bar. I'll try and find out the formulae for you.
    [/ QUOTE ]
    Same as me ! In a an a3 , still dont understand that mate ! [img]/ubbthreads/images/graemlins/confused.gif[/img]
    [/ QUOTE ]
    Jim, if that N/W meet gets sorted out, I'll plug cag comm into your car and we can log a few settings into nice graphs that show actual boost and requested boost. And compare yours to mine. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
    Oct 2003
    Wilmslow Cheshire
    336
    that would be great bud ! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Sep 2003
    Manchester
    340
    That looks very similar to mine, I have a 4th gear run some where.
    The reason I know it is similar, I was looking at the actual boost and it is way below the requested boost...Which I thought was odd compared to some other peoples I have seen. DO u have an N75J valave Mark?
    imported_20VT
    So looks like the stock boost is 0.8 bar ?
    And on the 225hp ?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,536
    My boost gauge gives me a max boost of 1.03 Bar
    on a 210 facelift model
    May 2003
    North West
    202
    Pure,
    everything is standard engine wise bar the remap, original DV, original N75 valve, intake hose etc.
    Mark
