210hp S3 stock boost
I
imported_20VT
Any know what the stock boost on a 210hp S3 is ? VAGCOM logs of group 115 would be nice /ubbthreads/images/graemlins/smile.gif
I logged group 115 using VAGCOM and it showed around 1800 mbar - are you sure its 1 bar ?
[ QUOTE ]
[/ QUOTE ]
Vagcome logs atmospheric pressure. If it states 1800mbar, then its actually 800mbar of boost.
Rich
[ QUOTE ]
jimboA3 said:
[ QUOTE ]
pure said:
There is an equation that can be used to convert mbar to PSI. Chipped I run/spike to about 24psi, but average about 20-22psi.
Not sure about stock. But I think that is about 1.4Bar. I'll try and find out the formulae for you.
[/ QUOTE ]
Same as me ! In a an a3 , still dont understand that mate ! /ubbthreads/images/graemlins/confused.gif
[/ QUOTE ]
Jim, if that N/W meet gets sorted out, I'll plug cag comm into your car and we can log a few settings into nice graphs that show actual boost and requested boost. And compare yours to mine. /ubbthreads/images/graemlins/laugh.gif
That looks very similar to mine, I have a 4th gear run some where.
The reason I know it is similar, I was looking at the actual boost and it is way below the requested boost...Which I thought was odd compared to some other peoples I have seen. DO u have an N75J valave Mark?
So looks like the stock boost is 0.8 bar ?
And on the 225hp ?
My boost gauge gives me a max boost of 1.03 Bar
on a 210 facelift model
Pure,
everything is standard engine wise bar the remap, original DV, original N75 valve, intake hose etc.
Mark
23
22K
7
981
979
