AH FabricationsChris Nott
Thread: Ticking Noise
    May 2009
    6
    Ticking Noise
    Hi
    I have an S3 which has developed a ticking noise which is heard most prominently at, erm, tickover.
    Speeds up and slows down with the engine revs.
    Anyone know what this would be?
    Ta
    H
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Charcoal filter maybe??
    Ross_S4
    Aug 2009
    Dundee
    718
    lift the bonnet and have a listen around the offside near the front, between the screenwash bottle and the engine coolant bottle.
    remove the offside plastic cover (one phillips screw at the rear i think) and nestled between screenwash, coolant and power steering fluid bottles is a black box with a wiring connector on top. when i checked mine i could feel it clicking as well as hear it.
    If that is where the noise is it is most likely from the charcoal filter, apparently a little solenoid there. I had it into see the audi mechanic when i heard it, turns out it wasn't a fault. you basically just have to live with it.
    May 2009
    6
    Ha ok. I don't have the car the mo, mum's borrowing it
    Will check later in the week and get back to you.
    What's a charcoal filter anyway? I thought I had an INTERNAL combustion engine?!
