EM TuningChris Nott
Results 1 to 10 of 10
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,274
    Strange rattle!!! A3 20VT
    here it most in second and third, put your foot on the accelorator, get alittle boost lift off, get a slight funny little rattle, sounds like from the passenger side front, near wheel, best as i can explain it its like a exhaust rattle, maybe think that as sounds alittle like metal.
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    indiemike's Avatar
    ZoomZoom
    May 2009
    North Wales
    385
    Ive got a few little squeeks and rattles on my car, been tryin 2 find out what they are for a while now but still none the wiser lol
    U might have more luck than me
    My Much Missed :Imola Yellow S3 - Revo stage 2, SPS3, RS6 reps, Pirelli P Zero Rosso, Cupra R splitter, Brembo's, 323mm EBC Turbo Grooved Discs, Ferrodo DS2500 Pads, Forge DV, Forge FMIC, Fidanza Aluminium Flywheel, Sachs Clutch, Green Cotton Dynatwist induction kit, 3" Downpipe, sports cat, Milltek cat back, Bilstein B8's, KW rear adjustable tie bars Whiteline Adjustable ARB's, Eibach Springs, Powerflex Bushes, Bose Concert System
    Now : Cupra R 225
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,274
    hope so, hopefully down to the road on the state, as its new and the road is a mess, somthing hopefully come alittle loose, but like i say, say you crawling in second, accelorate abit, getting some boost then let go of the accelorator makes like alittle rattle sounds like slightly loose metal, very annoying
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    524
    Only noise I can associate with what your describing is when the diverter valve is foobarred, happened on my car and the noise I got was like turbo chatter (compressor stall) which is no good for the turbo itself.
    Search on You Tube for this, there were some sound clips available. If it is the same as what you are getting, a replacement from the stealers is about 20 squids, Forge ones are around 70 squids, they are pretty easy to replace!
    HTH,
    Imteyaz.
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,274
    thanks very much for the info, will have a search
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Mine does it, front off side.... no idea what it is!.
    DV is fine (its a new 007), so I can only put it down to a heat shield or something.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Aug 2009
    Gloucestershire
    17
    Quote Originally Posted by paul26982 View Post
    also have the same noise, never got to the bottom of it. also have new forge dv. would be interested on your findings tho paul.
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,274
    let me have a look at the weekend, will try source it, keep the ideas coming
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,150
    Does it happen every time or only when the car is warming up?
    Only reason I ask is because I have a fluttering noise on boost when the car is cold but it goes after a few minutes. Its almost as if the car has a warm up cycle where one of the boost valves is letting pressure out of the system because the ECU is detecting a cold engine!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    paul26982's Avatar
    Aug 2009
    north east U.K
    1,274
    its once the car is warm i think ive noticed, but its not the fluttering, like i say slight bit of boost, foot off, sort of like a heat shield rattle but from front passenger, near wheel i think, just started doing it,
