Volks AutosChris Nott
Results 1 to 13 of 13
    Feb 2009
    83
    My S3 money pit!
    I feel my luck as gone form bad to worse since buying my S3 in February.
    I bought my 52 plate S3 with 52,000 miles, the lowest i could find, thinking that this would be trouble free, but th bills just kept on coming, as shown below:
    Cambelt and water pump with big service (haldex oil filter spark plugs...everything) 600
    4 new tyres because previous had cracked in tread 400
    New anti roll bar front, and bushes 210
    New front discs and pads 250
    EML comes on...Engine coolant sensor 70
    Passed MOT (thought the bills would be over) 52
    CV Boots split as coil pack goes 200
    Been told my MAF will need replacing soon, after that i don't think there is anything left to go wrong?
    But it all seems worth it, even though it costs me a furtune
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    why have you been told the MAF will need replacing soon ??? is your mechanic Psychic ?? what was wrong with the antiroll bar that it needed changing ??? and also 70 for a coolant sensor ???? that can't be right can it ??
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    eeek..your nearly at my repair costs..(although ive not had mine a month yet)
    heres my money pit - S3 money pit?
    Watch out for rear bearings..there not very nice to replace lol.
    My MAF will need replacing soon, im only hitting 192g/s wheras i would be hoping for 210ish.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,169
    Why should you be hitting 210 g/s, is your s3 remapped?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Other than normal servicable items such as cambelt, haldex, tyres, etc... the problems you seem to have had are fairly common.
    Please don't forget that the S3 would have cost someone around 27k new and just because you can get them for 6/7k nowadays, they are still a 27k car to maintain.
    No car is without its 'features' and the S3 by its nature has several of these.
    Just think yourself lucky you didn't have the extra 7k odd to buy an RS6!!!
    <tuffty/>
    S3KO4's Avatar
    Aug 2009
    London
    850
    Since 2007, owning my s3, I had replaced brakes, Tyres, fluids and serviceable parts no need to mention.
    Also replaced
    Steering rack second hand (350) with labour
    Clutch pedal snapped (90) to replace master cylinder Audi quoted 370
    Haldex pre pump and sensor, fluids and filter (350) second hand
    Gearbox mount screw snapped (30) to take out and replace
    Will need cam belt and water pump soon, just a bit longer to go I hope...
    Modified as pre signature
    Cost of 800 pounds
    And I still love every second of it, and not once I have wanted another car for better look or performance, very happy.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    random101's Avatar
    Sep 2009
    122
    in the last 6 weeks
    im spending about $1000 a week..
    wheels, brakes, coilovers, FMIC, revo chips, clutchs, gezzz you name it i got it lol
    well not really i guess next week will be turbos...
    2000 Audi S3 |Revo Stage 2+ | Revo Select Plus| Custom 3" exhaust |
    |3" down pipe | 120cell High Flow cat | Forge Dump valve |
    |Wagner-tuning FMIC ||Big brake kit 355mm | coilovers |
    ~Wish list~ |Haldex| stage 3+ |
    Feb 2009
    83
    Quote Originally Posted by 666markyboy View Post
    The sensor itself was by memory 30, but diagnostic time to find the fault then fit the new one took just under an hours labour then VAT makes it 70.
    And the MAF is a common fault, and with cars that are older, do generally benfit from a new one. Although not appearing to cause any problesm, the power loss through them as they start to go can hardly be noticable until it really goes wrong. He only advised me as a procortion
    Feb 2009
    83
    oh and anti roll bar needed to be reaplced due to the plastic sleeving splitting and falling out
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Im sure when my CV Boot split on the nearside it was only 50 parts and labour to have fixed???
    Sep 2009
    Ha! Your only at the begining!!! Does anyone have any stories of how they fixed everything and then it was amazing??
    Mine has been the most wonderful money pit I've ever owned! Good job its a bloody nice car to drive!
    In 3 months of ownership I've done:
    Service by audi (oil change)
    Haldex Controller (now performence)
    Haldex Unit and rear diff (x2 because 1st supplied replacement was no good)
    Anti Roll bars (now 26mm amd 24mm uprated)
    2 x MAF's (because they keep telling me its the problem)
    4 new coil packs
    new spark plugs
    Water pump (now metal)
    Cam belt (x2 because engine mount failed and damaged new belt)
    Engine mount (right side)
    Track rod end (left side)
    DV Valve
    All vacuum lines
    Oil breather hoses
    N75 valve
    N249 valve
    Intercooler hoses (now SFS silicone)
    Air filter (now green unit)
    Plus now it needs disks, pads and a clutch! This is all on a car with 100k and a full service history!!! Imagine if it was a dodgy motor! I refuse to ever sell a car if I know there's a problem with it otherwise It'd have gone after all this hassle but I'm hoping now.. finally.. I might be near the end of everything that fails and can enjoy some happy motoring?! Pleease!
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Once you get the thing to a well maintained level it should hopefully just be service costs. You got to remember that if you went out and bought any car that's 7+ years old you'll be replacing most of the parts mentioned above.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Ian W's Avatar
    Oct 2007
    Wirral, Merseyside
    1,054
    I bought mine on 75k two years ago.
    Since then I have had the following
    1st 3 Months
    Service 1 - Audi Independent - 500
    Cambelt / Waterpump etc - 500
    1st 12 Months
    Clutch + Flywheel - 950
    Broken Brake pipe - 120
    Window Regulator - 160
    Anti-Roll bars - 150 ish
    Last 12 Months
    1 Service I did myself - 120 for parts.
    Eventually you will get to the point where its mostly ok - hopefully, mines on 101k now and feels much better than when I bought it
