Sky InsuranceChris Nott
    Only me
    Mar 2009
    cambridge
    126
    Headlight switch
    hey has anyone got a guide for the headlight switch removal, as mine is playing up so i would like to get it out clean it up and see if that fixes things, any help would be nice tips or anything
    thanks guys and girls
    ruairi83's Avatar
    Dec 2007
    734
    id say you remove cover from fuse box then you can push switch out mate. fuse cover comes of, the fuse box screws out with 4-5 screws you can see the relays and switch from there...
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,441
    Quote Originally Posted by ruairi83 View Post
    Nono, you can see it, but you don't remove it like that....
    What you need to do is grab the knob bit you rotate and push it inwards, it's spring loaded, then I think you need to twist it anti clockwise until you can feel it stop and pull the whole thing out. There will be 2 connectors you need to remove, one is for the lights, the other is for the dimmer/headlamp height adjuster.
    Only me
    Mar 2009
    cambridge
    126
    jojo you were right, after i had taken it out found out that one of the springs had fallen out as the plastic that holds it in and broken away but i did mange to find it so might try and glue it, other whys dose anyone know if you can get just the knob itself? thanks
    jcs356's Avatar
    Brum brum
    Jun 2004
    Englandland
    2,681
    Nope, it's a whole unit. I had a similar problem on mine with a bit of the plastic which got jammed in the switch so when I switched the lights on my front fogs came on as well. Not wanting to look like a chav with front fogs on I priced up a new unit, nearly fainted, then got one off eBay off someone breaking an S3.
    Jason
    2001 Nogaro S3 (daily driver)
    1958 replica Porsche 356 Speedster (summer posing)
    1997 Seat Cordoba SX 16v (track day toy) replacing (t)rusty 1994 Seat Ibiza GTi RIP
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    I have a headlight switch for an A3 at home that's no use to me anymore as I've got the S3 now - It's fully functional but has a small scratch on the knob itself (that's why i ended up replacing it)
    if it would be of use to you drop me a PM
    Mike
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
