Badger5Chris Nott
Results 1 to 11 of 11
    Oct 2008
    188
    Audi A3 quattro and S3 gearboxes
    can any one tell me if these gearboxes are the same also do u think the driveshafts would also be the same a3 quattro turbo sport and an s3
    S3KO4's Avatar
    Aug 2009
    London
    850
    I would be interested to know 2, I have heard its the same but not sure, apparently the dual-mass clutch & fly wheel are simillar as well.
    S3-8L REVO stage 2, Milltek, 3" DP & custom 3" decat, RS2 spark plugs, 4 bar FPR, Green-Cotton uprated upper/lower boost hose & TIP, Front Zimmerman & Ferrodo. LCR spliter. boost gauge, smoothed AB. Aero blades, H&R 5mm spacers. Best time 14.03sec, 0-62 in 5.7sec. 207gs @ 25psi , polished inlet mani. VAGCOM 805.1
    Oct 2008
    188
    ive got 5 speed fitted in car at the moment but got a six speed out of tt to put in thought they should be the same cause when my road speed sensor failed audi kept giving me a 5 speed one witch didnt fit was to small it ended up beein a six speed one i needed also the starter motor was a six speed one i needed but the gearbox only has five gears so do u think it should fit
    Oct 2005
    brighton
    27
    Quote Originally Posted by djdougalno1 View Post
    I've got a 6 speed S3 box for sale out of a w reg 200 if anyone wants one complete with transfer box
    Only me
    Mar 2009
    cambridge
    126
    did they even do a a3 quattro with a 5speed box? i thought all quattro's a3, s3 and tt were 6speed boxes?
    Oct 2008
    188
    mines defo a five speed but its in a 6 speed case for some reason
    Jun 2006
    6
    Not sure but will ask the garage tomorrow as I have just had my S3 gearbox replaced, due to no 1st and 2nd gear.
    Jun 2007
    446
    my a3 quattro is 5speed. its a 6speed box minus the 6th gear
    Oct 2008
    188
    dose that mean the driveshafts wouldbe the same also
    Only me
    Mar 2009
    cambridge
    126
    dose that mean you 5speed lot can hit 60 in 2nd then, or have they lost the top end?
    RIP S3dave
    May 2004
    nr Glos
    7,162
    why do you want to change the drive shafts tho?
    they should just bolt up from 5sp car onto 6spd box,
    S3 shafts are going to be longer I think as their wishbones are wider slightly.
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
