Chris NottBadger5
Thread: ECU swap??
    Aug 2009
    169
    ECU swap??
    I've had a thought that may or may not work and I wondered if someone on here may know? If I were to swap my ECU from my 1.6 A3 to an ECU from a VW Golf 1.6 FSi would the Audi then run the 113bhp that the Golf has and 114ft-lbs torque instead?? The gains would be about the same as a re-map but I'd of thought an ECU from a scrapped car would be cheaper. Or am I just talking cr*p??
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Is the Audi 1.6 even an FSI engine?
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    If that was the case then you would be able to just remap the current ECU but I should think there would be more to it than just changing the ECU... your A3 probably won't have all the sensors the Golf has depending on the year of yours and the donor car for a start.
    <tuffty/>
    Aug 2009
    169
    "Is the Audi 1.6 even an FSI engine?"
    Nope, does that make a difference? I just assumed the ECU was just a computer that told the engine how to work, amount of fuel/air/when to spark power curves and what not? I though the "hardware" side of the engine wouldn't make much difference.
    " If that was the case then you would be able to just remap the current ECU but I should think there would be more to it than just changing the ECU... your A3 probably won't have all the sensors the Golf has depending on the year of yours and the donor car for a start."
    I have no idea how many plugs and sensors are on mine or the Golf. Just wondered if it would be possible and if it would work. Do I assume the Golf has more "extras"?
