Badger5Chris Nott
    Sep 2009
    How to install cruise control Audi A3 8L
    Hi,
    This is my first post in this forum. After having searched the internet for several days trying to find a usefull guide on how to install cruise control in my Audi A3 8L 1.9 tdi without any luck, Im posting this thread in hope for some help.
    I bought the original parts for the job at my local Audi dealer. All the fittings are installed eccept the wiring. I Cant find where the connections go.
    Did anyone have any luck finding an online guide??
    Any help is appriciated
    Regards
    Frederik
    subby's Avatar
    May 2009
    128
    this is the best guide there is:
    http://vwgolfr32.co.uk/ccs.pdf but it takes a while to make sense of it.
    I fitted it to my 2001 S3 easily enough, and the TDI's have the extra loom already so it should be even easier. PM me if you have any problems.
    1996 JDM Celica GT Four
    Sep 2009
    thanks
    Hi sobby,
    Thanks for the answer. I had a look on the guide, but my wiring ( org. Audi) do not look anything like the pic shown. - It has no loose wire. every end has a socket..
    Had a "weekend mec." do the job, but it dosent work. Mayby a program error?
    We have programmed the engine with code 11463 and got a "g" in the engine code, but still not results.
    Any inputs?
    Regards
    Frederik
    27,126
    whats ur engine & gearbox code
    Dec 2013
    Cruise control wiring
    Quote Originally Posted by subby View Post
    Is this post still alive? I have problems figuring out how to wire cruise control to ECU (Audi A3 8L 1.9 66 kW). Which wire goes where? Anyone could help me?
Tags for this Thread
