Aircon problem
maznaz
NULL
Hello, my first message in this forum. At first I would like to thank all for good info and coments. Allready found much interesting. Thanks.
I have 1,8T and have problem with clima system. Usually it works fine, but in longer jornejs after nonstop driving ~1h or a bit longer, working in Auto mode it cuts off, it cuts off not only cold air but air at all. I switch to Econ for 5-10 minits and it goes back to normal. It seams somekind overheating security? Sallon air filter is changed frequently and it is ok, system is mainteined ones at year so all components have no wisible foults. I even tested it with VAG diagnostic system but it shows no problems. Of course I can not test it in foult moment. Also I found that system generates very much condensate, it seems more than it should be...
So probably someone are familliar with such problem?
I live and drive in Latvia so it is not the hottest spot :)
thanks
Check the fans at the front (under bonnet behind radiator) to see if they are turning okay. Had a problem once where the aircon fan broke and caused issues with the system, replaced and all fine. Failing that have a look at the 'Air Con' forum to see if there is any other info in there.
one of fans ratle a bit, but they boath are working
i was told that if the condesor gets moisture in it thats the kind of problems to expect.........maybe something to consider
680
610
751
imported_Stewart
I
392
391
