Sky InsuranceJMB Retrofits
    Sep 2008
    17
    Water pump change... should I do it?
    Hi guys,
    Ive got a 225 s3 02 plate... Needs a water pump change... Ive downloaded a manual telling me how to do it but i just wanted to check whether I could do it myself without a timing belt tool? I dont want to pay 200+ to get it changed. Ive brought it already for 35, and according to the manual it is a hard job, nothing that looks too difficult for me though, however would the lack of a timing belt tool get in the way? PS Im not looking at replacing the timing belt or tensioner as of yet...
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    yes, you can do it without any special tool
    this might help:
    http://forums.vwvortex.com/zerothread?id=2271429
    ^^ In my opinion
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    TBH, as you have to more or less remove and replace the cambelt anyway, I would replace it anyway for the sake of a few extra pounds...
    If the waterpump is struggling, it might have caused some damage to the belt that you don't know about.
    It also then should not need doing again for another 60k/4years...
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    If you need to ask, then it's probably not worth taking the risk. Also as mentioned by Alistair if you're changing the water pump it's advisable to replace the timing belt too. It only costs around 15 from a decent parts store.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    I've just done the timing belt on my one last week at my mates garage.
    TBH if ur doing the water pump, you might as well do the whole thing as you have to strip the whole lot to get into it.
    Believe me it's a nightmare of a job even with the proper tools & ramp!
    you need to take the coolant water bottle & power steering bottles off, then support the engine underneath before taking the engine mount off.
    The other thing i will say, is dont worry about the timing belt tool. As long as you mark everything up before you remove the old belt it should be fine. Just remember to turn it over by hand a couple of times to make sure it all lines up again after the rotation.
    ...... Now this one's MUCH better!...
