Results 1 to 36 of 36
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    S3.. thoughts please people?
    My friend is looking to but an S3. We went to view one today in Northampton it was a 2000 reg 8L with 98k on, full Audi service history, a very comprehensive history of any work carried out including all MOTs etc. It's an APY engine code and has had a Revo map to 260HP.
    The car performed very well and the engine seemed very well maintained. I took my VAG hand held scanner to check for trouble codes and got..
    17748.P1340 camshaft position sensor G40/engine speed sensor - G28: incorrect allocation.
    I have consulted the Ross Tech code reference page and it seems the problem is either a faulty G40/G28 sensor or the timing belt/chain is positioned incorrectly (the timing is out).
    As the car performed well and idled perfectly I pressume it is a faulty sensor as there is no evidence of bad timing. The cam belt or head have not been worked on/removed since the cam belt change at 70k.
    Any thought??
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    GO back for a 2nd test drive but clear the codes first and see if they come back after the drive. They may be old faults that haven't been cleared after they were fixed.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Oct 2007
    UK - Midlands
    2,223
    That was my intention but my mate bit the bullet and put a deposit down so it looks like there will be much more time to investigate further now.
    No doubt he'll be making an appearance on here soon.. I'll keep you posted.
    Cheers.
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    How much did he get it for?
    Sounds good to me.
    And he has a mate with all the gear...!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by ianysm View Post
    Sounds good to me.
    5K and he collected it yesterday.
    Turns out there may be a slight issue with it after all!
    I'll explain in more detail in my following post...
    Oct 2007
    UK - Midlands
    2,223
    My mate turned up at my house yesterday so we took his new S3 out for a blast up the dual carriageway.
    Apparently it is not running right...
    Up to 4000 revs the car feels fine but with the pedal to the floor at this point (turbo building pressure) there is a definite what could be described as a stutter. This 'stutter' then repeats intermittently up to red line.
    Obviously the place to start looking is the fault code so I was planning..
    1) Check the timing (TDC) marks all line up and that the number of teeth/links between points on the cam belt/chain are correct.
    If the above is ok and the chain hasn't stretched etc. I will..
    2) Check/replace the involved sensor or wiring.
    3) Cry and kick the sh!t out of his new car!! lol
    So what would you do?
    Oct 2007
    UK - Midlands
    2,223
    Oh yeah.. and a big thank you to the 'S3 24 hour helpline' AKA Tufftybloke
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    724
    It sounds like you didn't take it out for a proper test drive before buying it.
    But then again you were thorough in your pre-inspection tests (vag com), which I must say I would not have done.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,425
    Quote Originally Posted by Lee Goodall View Post
    Have you tried disconnecting the MAF sensor and driving it? The symptoms you describe could be a faulty MAF sensor also. I've noticed from past experience that the failure of one part/sensor can bring up all sorts of fault codes when using VAGCOM to diagnose, like a chain reaction if you like. Also, does it fireup easily? a knackered crank sensor makes it difficult to start I think.
    You've got to have a laugh!
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by thegoal007 View Post
    To be honest I wasn't driving the car and for a radius of about 3 miles from where the car was situated it was littered with speed bumps. The one section of road where we did get some good speed up I was in the rear of the car. The car does pull very well and I couldn't at that time see that there was a problem.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    You are welcome d00de although just sorry I couldn't get to my PC to have a quick look for anything else relating to the prob
    Hope you get it sorted...
    If the cambelt has slipped a tooth, I am pretty sure the engine wouldn't run as well as it does up to 4k, really need to log it in VAGCOM
    Mine used to be a bit fluttery due to an issue with knock sensor 1.
    Good luck with checking TDC, easiest way to do it I can think of would be to pin back serpentine belt tensioner, remove the bolts holding crank pulley on, align the crank marks then tease open the cam cover to view the cam pulley marks as its a complete git to take off on an S3/transverse engine...
    <tuffty/>
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by jojo View Post
    Not tried with the MAF disconnected. Wont it run badly anyway with the MAF disconnected?.. I know my AEB does.
    It starts first time.
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by tufftybloke View Post
    <tuffty/>
    Wouldn't have expected you to look it up for us mate.. your input was greatly received
    Yeah.. the fact that it's only after 4k ish kind of ruled out bad timing in my mind as surely it would suffer throughout the rev range? What about variable valve timing?
    I'll try to run a log asap.
    Feckin transverse engines suck @ss lol.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,425
    No, if the MAF is faulty, then disconnecting it will make it run smoothly, but in a default setting, so the car will be running less power than standard. It will also flag up some fault codes which can be reset by VagCom, though these usually disappear when you reconnect your MAF - at least it does on my car anyways.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,425
    The VVT system is only there for emmisions reasons, it does nothing for the performance what so ever.
    Oct 2007
    UK - Midlands
    2,223
    I was just thinking that maybe if the engine speed sensor/cam position sensor was acting up then it may in turn influence the VVT system and the smooth running of the engine.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    Fairly sure APY is non VVT tbh...
    <tuffty/>
    fran-s3's Avatar
    1,090
    Wish I would of seen this sooner, would of come down with you to check it out. (northampton here to) I had this error on mine when my cam-belt wasn't put on properelly first time round by what i thought was a good mechanic..(long story!) Striaght back got a refund and took it to a proper VAG mechanic and got it sorted... he was shocked! My proper mechanic said the rubber was slowly wearing as it wasn't aligned properelly on other parts, and showed me! Obv I had the waterpump changed to. Really hope it's just the sensor and not the cambelt mate.
    Did the engine warning light stay on when you were driving it? Mine did.
    Leon's Avatar
    Jul 2003
    Manchester
    147
    I had a very similar problem with mine because the speed sensor was faulty. It would rev normally till around 4K then just stutter, jerk etc. Basically the engine was cutting back power for safety because of the faulty sensor. 120 later (and its the second time it has gone) the fault cleared. Hope your mate gets it sorted.
    AMK Goodwood Green S3 - AMD 265BHP remap - Chrome Mirrors - Sunroof - Bose Symphony - DICE IPOD Kit - 18" DOTZ Mugello's - And a Yamaha R6 for when it doesn't rain!
    fran-s3's Avatar
    1,090
    Sorry read your second review properelly now... is it remapped do u know?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    First post mate... Revo
    <tuffty/>
    fran-s3's Avatar
    1,090
    whoooooooooooops whats wrong with me! Ok well err tuffty seems to be on the case here!
    Oct 2007
    UK - Midlands
    2,223
    <tuffty/>
    Ha ha that rules that out then
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by fran-s3 View Post
    Hmmm??.. were there any signs of poor running with yours?
    He's had no warning light at all AFAIK.
    Yeah fingers crossed that it's only a faulty sensor.
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Leon View Post
    This is identical to what he's getting.. most of the evidence is pointing towards the speed sensor.
    The cam belt hasn't been touched since 70K so unless the chain has stretched I think that can be ruled out.
    Did you test the sensor before replacing mate?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    If the crank sensor is playing up, it will normally throw a code, and maybe cut out. Sometimes even will be hard to start.
    Tell the truth, you sabotaged him so you were faster,lol
  28. #27
    fran-s3's Avatar
    1,090
    There wasn't any signs of poor running when my cam belt wasn't tensioned properelly. Drove fine apart from the warning light coming on and staying on.. So it's odd the warning light hasn't stayed on for your friends car. Looks like the speed sensor could be the route to go down then....
  29. #28
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    There is a code (see first post)
  30. #29
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    I bet its still on its original coil packs too?
    AUTOMAP
    www.eliteremaps.com
  31. #30
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,449
    This the page you looked at Lee?
    http://wiki.ross-tech.com/index.php/17748/P1340/004928
    If you get hold of VAGCOM or maybe your handheld does the same, this may also be of use to you..
    http://www.ross-tech.com/vag-com/m_blocks/
    The wiki suggests using a measuring block to determine if the timing chain is an issue... camshaft stuff appears to be blocks 090 to 098 but I couldn't tell you which one to use...
    Someone with ElsaWin handy may be able to shed some light on the diagnostic procedure for this...
    <tuffty/>
  32. #31
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,990
    its your crank sensor...had exactly the same problem, it will get worse!! has it started cutting out yet when rolling to a stop? the code on vagcom was exactly the same as mine too....we worked out it was either the cam sensor and crank...crank was the obvious
    tis an arse to change and make sure you get the right bit if buying pattern..... its located just above the oil filter and secured by two bolts, once you remove these it can be an arse to get it out...once done though your onto a winner - good luck
    personally id rule out the coils as these would flag a seperate fault....
    Xbox 360 gamer ID : Timffy
    Grey Triumph Sprint 1050 ST
  33. #32
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,990
    as an add on cos ive just been arsed to read the whole thread...crank sensor can make it hard to restart if it conks out....although with mine it worked fine only giving me probs when it conked out....starting from cold was fine until it got warm 2-3miles away then started playing up gradually getting worse
  34. #33
    Oct 2007
    UK - Midlands
    2,223
    <tuffty/>
    Yeah.. that's the wiki page.
    I can view measuring blocks with my scanner too.. I've got ElsaWin so I'll have a look. Cheers mate.
    Got VAGCOM too but my lead is dead at the mo.
  35. #34
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by 1animal1 View Post
    No starting/stalling problems yet so there may be something else going on here.
    I will check the timing chain measuring blocks and if they are fine I'll swap the crank sensor.. if it's not the crank sensor then I'll just put it on ebay I suppose.
  36. #35
    AUDI S3, REVO MAPPED 260 bhp
    Sep 2009
    37
    Hi im lee's mate that has bought the S3. doesn't seem to have any other problems, and no warning lights on the dash. very fustrating though, as i want to test its full perfomance.
  37. #36
    Oct 2007
    UK - Midlands
    2,223
    OI OI... get in there
