JMB RetrofitsAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: Bloody misfire
  1. #41
    Sep 2006
    222
    Quote Originally Posted by ben_turbo1 View Post
    Ok but on the throttle body front it is a good idea to clean it every now and then, you can then re-set it via vag com.
    might clean it but dont know anyone with vagcom local to me
  3. #42
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    pretty sure you dont need vagcom to reset tb, ill try and find the 'how to' its on uk mk4's somewhere
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
  4. #43
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    2002 S3 REVO
  5. #44
    Sep 2006
    222
    Quote Originally Posted by s3 Hoggy View Post
    cheers for that,so you dont need to re-align it just unbolt it without disconecting the eletric part of it and hold down the throttle pedal,this means you can get at both sides without distrubing the throttle flap setting
  6. #45
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    I disconected the battery before doing anything, I cleaned the tb the way it shows on uk mk4's then re-assembled, reconected the battery then turned the key in the ignition (without starting the engine) and let it sort itself out for a couple of minutes,
    Thats all I done mate and it runs sweet as a nut. There was nothing wrong with my car to start with though I was just bored and thought I'd give it a go.
    Cheers Matt
    2002 S3 REVO
  7. #46
    Sep 2006
    222
    fitted the new maf and cleaned the throttle body,as far as i can tell it may have cured the fault,i cleared the codes and went for a 10 mile test,no fault codes logged when i got back,will have to see if it happens again
  8. #47
    Sep 2006
    222
    looks like it may be fixed,,,,
  9. #48
    MAF
    MAF sensors are a pain, I had 2 brand new sensors that gave erratic running, stalling, not reving by 4k etc..etc..before sorting it out with a 3rd new sensor.....
