VAGCOM results
kitpayne
Warminster, Wiltshire
Hey all. I just received my VAGCOM lead - the one from ebay. I just got it working - on the limited version and this is what it said.
VAG-COM Version: Release 409.1-US
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 8L0 906 018 K
Component: 1.8L R4/5VT 0003
Coding: 05610
Shop #: WSC 06435
6 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-00 - -
16795 - Shareware Version. To Decode all DTCs
P0411 - 35-10 - Please Register/Activate - Intermittent
17925 - Shareware Version. To Decode all DTCs
P1517 - 35-10 - Please Register/Activate - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Shareware Version. To Decode all DTCs
P0102 - 35-10 - Please Register/Activate - Intermittent
18017 - Shareware Version. To Decode all DTCs
P1609 - 35-00 - Please Register/Activate
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 C
Component: ABS/EDS 20 IE CAN V003
Coding: 13504
Shop #: WSC 06435
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
I read somewhere to clear them and check again some when else. Should i do this, as they could be old faults, or should i check out the problems? Think i'm gonna have to buy the licence!!
Also what other sort of useful stuff can i do with the software?
Clear & then drive & check again cause camshaft one wont come back until driven for very short distance but will show up again given I had this, then come back with list to us..
If you ever want a genuine cable then PM me as I sell these.
ok cheers. that was what i thought, just didn't want to go tinkering and f*!k it up. Will post new results wednesday as am working til then. cheers :icon_thumright:
846
9
959
