Volks AutosEM Tuning
Results 1 to 19 of 19
Thread: S3 Head gasket
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    S3 Head gasket
    My wifes headgasket has gone on her 03 S3. Iys covered 104500 miles. I think this is premature but do they fail early? Any thoughts? Cheers.
    1animal1's Avatar
    The Clar!! it mouves!!!
    Dec 2007
    Sheffield
    9,985
    ive not heard of one going yet..... i was worried when i bought mine as the oil cap had cream on the inside, this engine is prone to condensation and mine ended up being spot on once id ran it for a week off the forecourt......
    Xbox 360 gamer ID : Timffy
    Black FZ6 - Turbo car 'slapper'
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    The last 6 months its been using water. Long story but I only found out 2 months ago. No leaks so I had an inkling what was happening. No mayo or anything just using water. In the last 2 months its dropped 2 coils as well. Anyway Its booked in and is going to cost us Ł400. God knows what Audi would charge?
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    coils are a usual thing to go at that age, normally prompted by a remap
    if i were you id just change all 4 coils as if one goes down away from home she'll be runnin on 3 cylinders which could potentially kill the cat from the unburnt fuel burning through it
    I gather you've checked every other avenue before assuming head gasket? like pipes, any external signs if it isnt infact seaping into the oil - gotta say the HG is rare
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Yep checked everything. My mates a very good mechanic and he has carried out the head gasket check and it confirmed it. When you take the header cap off its goes off like a shook up bottle of coke.
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    oooh never good..... well best of luck with it, he may aswell check the turbo whilst its all off, the K04 unit is known for cracked housings near the wastegate IIRC
    i think you've done well for Ł400, my neighbour whos a good mechanic took 6-8 hours to replace one with ramp (first S3 he had worked on, he's used to VAG though)....says its a right pain especially when trying to remove the oil feed to the turbo
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Cheers for that I'll tell him about the turbo. He's going to carry out work after hours cash. He has a pro street rod so it pays for his racing He has done a few so is happy with it. He would rather work on that more than my V6 vectra LOL
    1animal1's Avatar
    Dec 2007
    Sheffield
    9,985
    ah yeah....got ya on that one
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Looks like the head gasket has gone again. Does anyone know if there are different types of gasket for the 1.8? Anyone know if there is an uprated gasket for this engine? I bought the gasket from Audi so it was a gen one fitted last time, the head was skimmed so we dont understand why its gone again?
    Sep 2009
    Essex
    2,366
    compression tested it?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    Bit strange! I remember reading this thread last year and hadn't heard of one ever going let alone twice on the same car. Has it definitely been confirmed that the gasket has failed again?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Chugger
    North Devon
    2,716
    using water again but no cream? Not sure if its possible for the water/oil coolers to fail on these. But that would result in the creamy oil or water. What are the symptoms?
    57 A3 2.0 TDI Sportback (140)
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Not comp tested it, garage is pressure testing this afternoon. Its loosing water and not leaking. When starting the car up in the morning and afternoon it takes a good 10 to 15 secs to start and its really lumpy, sounds like a diesel starting, it did this last time and after the HG was replaced it fired up first turn of engine. It also holds back sometimes and now and again you can feel it sort of cutting back, your foot is constant but the car feels like its just dropped 200/500rpm. Its a stranged feeling like backing off the throttle but not actually moving it. Its making my Vx heap look reliable LOL
    This might be a fix and sell and time to get the S4 I want
    Sep 2009
    Essex
    2,366
    S4s rock. Mine sold lastnight
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Finally had the garage take a look at it. Water is pooling on No2 piston. Pressure checks fine at idle but is out of limits when revved. Looks like gasket or head cracked, hoping its the gasket as itll be under a warrenty claim. Knowing my luck at the mo its the poxy head!
    Chugger
    North Devon
    2,716
    Thats unlucky, im sure second hand heads are readily available though.
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Quote Originally Posted by sportstractor View Post
    Wont know for deffo for 3ish weeks, garage is really busy. Will be looking for a new head though just in case.
    barters3's Avatar
    May 2008
    440
    head cracked on mine. cost Ł1200 in the end!
    that was based on Ł400 for a head gasket replacement, Ł600 for the head, and the rest on seals etc and labour to remove and clean pistons as some had coolant on them.
    fluffsri's Avatar
    Jan 2007
    Shaftesbury, Dorset
    58
    Blimey! Just found replacement head on Ebay for Ł230 as a blank.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Will hve to wait and see now and find out when its dismantled, I have everthing crossed its the gasket LOL
