Sky InsuranceVolks Autos
Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
Thread: ARBs Help
  1. #41
    Jun 2009
    What are the preferred choice of aftermarket dampers these days?
    Josh
  3. #42
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    Quote Originally Posted by Super Josh View Post
    Josh
    I've got Bilstein B8's waiting to go on my S3 one the rest of my suspension bits arrive - they seem to get very good reviews.
    Koni FSD's are another option
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
  4. #43
    Andy_S3's Avatar
    May 2007
    Teesside
    719
    Ive got the B8s/H&R setup on mine, faultless imo!
  5. #44
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Josh
    It depends on the far in my view...it's not a 'one size fit's all' answer.
    If S3, then Bilstein B8s, H&R springs, adjustable tie bars and ARBs to choice, work really well.
    If A3, then I'd look differently.
    Probably H&R or Eibach springs with some form of adjustable dampers (I prefer the rear dampers much stiffer than the fronts on a FWD car) and perhaps ARBs on top.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
  6. #45
    Jun 2009
    1,069
    Does your s3 comment aplly to my a3, as its quattro to. will that set up bring the handling above any over hot hatch on sale.
    Its gone replaced with a mk2 golf gti 16v :D
  7. #46
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by emery1990 View Post
    Yeah, 1.8Tq and S3 are interchangable with the basics, but I'm not sure if you can get as much negative camber on the front, compared to the S3.
    But, springs, dampers, ARBs, tie-bars etc are all common.
    As for getting the handling to a level above any other hot hatch...that's a tough one.
    Don't forget the S3 is 10 years old now...and although you can vastly improve the chassis, you can't work miracles...and some 'newer' cars just have a better chassis out of the box.
    For example, my S3 when fully sorted felt similar to a bog standard Mk5 Golf GTI - the GTI is that good.
    That being said, if you do change the suspension to some quality replacements, it'll certainly be up there with the good ones....but will you ever make a road going A3/S3 out-handle a Clio Trophy, Megane R26R etc? No. I doubt it.
    Please note:
  8. #47
    Bring on the Ice!!
    Jun 2006
    Edinburgh
    59
    Quote Originally Posted by Ess_Three View Post
    Just finished getting my set up finally completed (with many thanks to Starperformance and Ess for work and advice).
    Now got Bilstein B8s, H&R springs, adjustable tie bars and Neuspeed 22mm front and R32 19mm rear ARBs.
    feels fantastic!
    S3 2001, Met Blk, Blk leather, armrest, cruise control, alu WM, TTRS 18s, Bose, Revo, H&R, Billies, FMIC, porsche GT3 calipers, R32 disks, quickshifter, new S3 gearstick, Neuspeed/R32 ARBs
  9. #48
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,283
    Bloody Hell Steve you don't hang about!
    If you dont mind my asking, how much did it all cost you?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
  10. #49
    Bring on the Ice!!
    Jun 2006
    Edinburgh
    59
    The car came with the H&R springs already on, and the rest i did in essentially 2 steps
    1: Bilstein sprints + tie bars 868.70 (inc fitting)
    2: Neuspeed ARB (22mm)159.50 + 11.30 (delivery) (+vat)
    R32 19mm rear 173.04
    4-wheel alignment
    plus labour and various bushes 52.60
    + vat
    it also needed front (R+L) connecting links
    Total = approx 1500-1600 (thats covers pretty much everything)
    the labour probably would have been cheaper if it was done in one go.
    all the parts were pretty shot so needed doing anyway
    they should hopefully only need doing the once, so thought may as well do them right first time
