Volks AutosMonster Motorsport
Results 1 to 15 of 15
Thread: DV diagnosis
    Jun 2009
    186
    DV diagnosis
    Morning,
    Need a bit of help, I think my DVs gone but would be very helpful if someone could confirm.
    Basically turbo starts the faint whistle, when I pull in the clutch and change gear it makes a weird sound, not a whoosh like a turbo dumping but definitely sounds like air with a bit of something else. Only started recently.
    Much appreciated
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    Is it a standard valve or an after market one?
    take it off and check the diaphram if it is standard.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jun 2009
    186
    Thanks for the quick reply, its standard (100k miles on it!), how do I check it?
    Any ideas what else it could be if its not the DV, as it only does it when I change gears?
    Westy's Avatar
    Dec 2008
    17,263
    If its the original valve from new I'd chang it if I was you.
    Do you notice a fluttering noise when the turbo kicks in and you're accelerating?
    The DV is located to the right of the engine as you face it near the back. Remove it and unscrew it and there is a rubber diaphram inside, check that for splits. If it all looks ok then we'll think of some other things to check.
    S3 Build Thread
    Jun 2009
    186
    Quote Originally Posted by Westle View Post
    Okay, will do. Do you know if VW sell the same part? No Audi near work.
    Havent noticed it, just the usual turbo sound through the revs, but now I will listen out for it. Will it flutter throughout the rev range and will it be obvious or faint?
    Thanks again.
    Westy's Avatar
    Dec 2008
    17,263
    Wind down your windows and it should be quite obvious. The flutter will occur when the turbo starts to spool as it is the sound of boost leaking through the split diaphram.
    S3 Build Thread
    Jun 2009
    186
    Will try at lunchtime, tbh cant say I have heard it, roads are wet so a bit of a pain to hear anything though.
    I ran Vagcom and no errors were present.
    Jun 2009
    186
    Westle, would it be worthwhile upgrading to a Forge DV, I think its an AGU (2000 model), which forge should I look for if so. Is there any maintenance required for them?
    Westy's Avatar
    Dec 2008
    17,263
    Go for this one. The Forge 007P:
    Forge 007P DV Down To 79
    Hardly any maintenance, only need to regrease the piston every year.
    S3 Build Thread
    Jun 2009
    186
    Decided to opt for the stock DV in the end, couldnt justify the 80. The guy at audi sold me the 710N valve though as he said it was specified for my car. Will fit today, and get back.
    Westy's Avatar
    Dec 2008
    17,263
    Did you check the diaphram before buying a new valve?
    S3 Build Thread
    Jun 2009
    186
    Yet to fit, if its okay, I may take the part back to audi.
    tbh been thinking about getting new hoses, dv etc as part of good maintenance as the car has touched 100k. DV was 28 after VAT if anyone else is thinking about it.
    Jun 2009
    186
    Changed the DV from a 710G to a 710N.
    Difference - Turbo seems quieter, in lower revs the turbo feels like it kicks a very little more.
    710G diaphragm was fine.
    Westy's Avatar
    Dec 2008
    17,263
    So do you think your problem is fixed?
    S3 Build Thread
    Jun 2009
    186
    The noise is still there, it does it when the motors cold and idling to, had a look under the car and I think its the heatshield on the cat, making a slight vibration at certain engine load or idle when its cold.
    The new DV is definitely an improvement though, so wasnt a waste of money as low rev range pickup is better and mpg went up by 0.3.
    Thanks for your help Westle.
