Volks AutosEM Tuning
Results 1 to 7 of 7
    Aug 2009
    169
    Wheel spacer questions
    So I'm thinking of fitting wheelspacers. But I though I'd access this fountain of knowledge with a few questions before I dive in.
    1) Where can I get them from and how much?(Except AMD, 48.30 per wheel!?!)
    2) Which types(if they make more than one, cast washer style or billet with offset threads) are better?
    3) How wide can I go before I hit problems?
    4) Anyone fitted them and found problems?
    5) Generally are they a good idea?
    s4marsh's Avatar
    Jul 2009
    middlesbrough
    357
    esp engineering are your best bet i used them the other week and they're top quality and the cheapest in the uk i think i'd stick to 10-15mm personally it makes a big difference to the look
    ESP Engineering
    Unit 2, St. Florian House
    Brooklands Park Industrial Estate
    Crowborough
    East Sussex
    TN6 2JR
    Tel: 01892 613292
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    I agree... I got my 10mm ones from his ebay shop...
    http://shop.ebay.co.uk/espengtn6/m.html
    On my S3 I have 15mm rear and 10mm front
    <tuffty/>
    02audis3's Avatar
    Aug 2009
    133
    How do you fit the spacers? Dont need to weld them on to the alloys do you
    ianysm's Avatar
    Oct 2008
    Midlands
    1,002
    I fancy some of these. How do they effect handling. Good points, any bad points?
    To fit them you just need longer wheel bolts then the wheels bolt back on through the spacers, job done!
    AUTOMAP
    Mobile ECU Remapping Services
    automap.remapping@gmail.com
    www.eliteremaps.com
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    The ESP ones on ebay come with bolts... Had to cut them down a bit for the 10mm ones as they were too long... The guy knows this though... I did a 'Make an offer' on the auction of 45, won them at that price.... bargain
    <tuffty/>
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Quote Originally Posted by ianysm View Post
    They can make torque steer worse, and if you go silly wide, can speed up wheel bearing wear.
    I doubt you'll notice much difference with 10-16mm spacers on an S3 though, I didn't.
    I fitted 13mm spacers to my Fabia vRS though, and it was awful...torque steered all over the place. They lasted a few days...then into the bottom of the toolbox they went.
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
