JMB RetrofitsSky Insurance
Thread: ESP problem
    May 2009
    24
    ESP problem
    Hi,
    I have a 52 1.8t and have started having trouble intermittently (Sp) with the ESP coming on when I put the foot down on perfectly straight/ dry roads. It will cut the power, so I turn the ESP off for a few secs and this seems to cure the issue for a while. This has now happened a couple or three times and its starting to feel like an expensive fix!
    Any clues Boys and Girls?
    thanks
    Gareth
    Essflee's Avatar
    Mar 2008
    2,007
    Is this happening in 1st and 2nd gear or at higher speeds ?
    revo'd
    May 2009
    24
    Both, the car isn't losing traction. It tends to be after the ESP activated after going round a corner etc.
    subby's Avatar
    May 2009
    128
    abs sensor ?
    Have you done a vag-com scan ?
    1996 JDM Celica GT Four
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    has your car been mapped because I noticed that the ESP was slightly more sensitive after a map.
    Get it scanned because it could be a faulty wheel speed sensor which is about 35 for part and 1 hours labour.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
