Chris NottVolks Autos
Results 1 to 10 of 10
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    Thumbs down Clutch pedal snapped
    travelling half mile down the road to the girlfriends and low and behold the clutch pedal snapped! Stranded on a sat night.
    Whats the process for fixing it? How much for a new pedal? I have noticed the pedal has snapped off some plastic, and the rod into the master cylinder is slightly bent. Any ideas will be much appreciate!
    Thankyou
    2002 225 S3, metallic black, REVO, 18" RSTT alloys, goodyear Eagle F1s, silver leather heated seats, tinted windows, H&R spacers, black diamond grooved discs & Ferrodo DS2500 pads, BOSE system, xenons, forge DV, samco TIP & upper boost hoses.
    Dec 2005
    UK
    115
    20 for the pedal. 7 for new plastic bits and bushes. 30 minutes to an hour to fit. Did mine a couple of weeks ago.
    wibble111's Avatar
    needs to scratch the itch
    Nov 2006
    derbyshire
    829
    Common problem i'm afraid mate. Have a look here.
    S3 8L Clutch Fubar'd!...
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    top job guys, thanks. Cant believe the rest of the car is built like a tank and this is a common problem! Only fixed another common problem, the door switch which keeps the interior lights on lol
    Happy days!
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    apart from the obvious place, audi stealers, were could i pick one up from at the weekend? If not ill have to book day off work to get one
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,089
    Get your old one rewelded, thats what i did... you can ensure a good weld all round the box that holds the plastic clip then... if you get a new one it's still gonna be the same ****ty bird poop weld that went in the first place and will go again in the future
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    ok cheers mate, any tips on how to get the bolt out at the top of clutch pedal itself? Because the spring is putting tension on it. Any tips for removal would be most appreciated
    Dec 2005
    UK
    115
    Depress the clutch pedal and use a large flat bladed screwdriver to remove the Spring assy. Dismantling is easy then. You have to remove the spring to get the bolt out. Don't lose the bush or the 2 spacers if you are not renewing them. You don't need any special tools to do this. the hardest bit is getting the spring back, but it is not too bad a job all in
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    iv done the job but the rod on the clutch cylinder is loose and once the clutch is up it falls out,so i have cable tie wrapped it up for time being. Am i missing something? Also the clutch pedal seams very high, higher than before. Can anyone explain this?
    campbell's Avatar
    Apr 2006
    Lancashire
    712
    ok i think there is a spacer which stops the clutch from fully coming up, can any look on there S3 for me please? The clutch is well high, and the spacer would then make the rod from the cylinder not fall down. Can some one double check for me please? Thankyou
