JMB RetrofitsChris Nott
    imported_a3person
    condensation on inside of headlights cover
    Hi, I am in the process of buying a used A3 (1.8 T) from approved Audi dealer. When doing the check around the car, I noticed there was condensation on the inside of the clear plastic sheet part that covers the headlights. This was only on the right hand light, the other one was fine. The guy at the dealer said this was normal as the car hadn't been used for a while and that it would go away after normal use. (He also said that if there was any probs to take it back under the 12 mth warranty. ) Is he right or should I be worried about this condensation? I thought it would be watertight around there. Also, do you reckon this will be covered under warranty??
    May 2004
    23
    Re: condensation on inside of headlights cover
    This is normal on the face lift headlights - nothing to be concerned about.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,570
    Agree with Bob.......its a common thing with the VAG group cars.
    Aug 2003
    Kent
    123
    Dealers will only change the lights if there are droplets of water running down the lens!
    Otherwise, nothing to worry about!
    Bushey, Herts
    58
    Its normal. Had my S3 for 6 months now and the fog light condensed up. Just turn on the lights and leave for 10 mins or so and should be clear again.
