Volks AutosBadger5
Results 1 to 8 of 8
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    What to use to remove spray adhesive glue?
    As subject I've bought a head lining from a scrap yard out of an A3 and I am hoping to use the material to cover something else [img]/ubbthreads/images/graemlins/wink.gif[/img]
    The only problem is that it's got foam backing that has been stuck to it buy strong adhesive.
    Any ideas what I can use to dissolve the glue and remove the foam backing?
    I know it's an odd one LOL
    Cheers Mark
    CARACTERE007's Avatar
    havin\' a giraffe
    319
    Re: What to use to remove spray adhesive glue?
    wd40 is realy good at removing sticky stuff
    imported_Robbyc
    There is some stuff called tardis which i have used in the past to remove glue. you might need to go to a valeters for that, bit of a pain but its good stuff.
    Apr 2004
    Scotland
    87
    Or Lakeland do something called Sticky stuff remover. Smells of orange and works quite well at disolving sticky stuff [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Don't know how effective it would be in your case though [img]/ubbthreads/images/graemlins/confused.gif[/img]
    May 2004
    Surrey
    310
    use lable remover from RS component or ard electronics?
    Really good and cheap?
    imported_highlander1
    At work we use nail polish remover to remove glue/labels and permanent marker. Its cheap and easy to get, The girlfriend/wife will have some.
    Cheers,
    h1.
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Hmm I may have a go at the nail polish remover, but I am not sure it will work.
    May 2004
    Surrey
    310
    TRUST ME
    http://www.ardelectronics.com
    product code = 370-00022
