Monster MotorsportEM Tuning
    barters3's Avatar
    May 2008
    440
    Spare rear diff or haldex unit?
    i was just wondering whether anybody has a spare haldex unit as i need the precharge pump from it.
    if anybody could help i would be gratefull if you could pm me.
    I apreciate that i should probably post this in the classifieds, however i feel i may get a larger response here, and im getting pretty desperate for the part!
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    Hi...
    I'm about to change my entire diff/haldex unit with controller and precharge pump.
    I'll have one which will be available very soon.
    G
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    BTW what has happened to your current one? Do you have a clicking/noise from the hadlex unit upon key turn in ignition?
    G
    barters3's Avatar
    May 2008
    440
    Bit of a long story... I had a very small leak from where the electrical connections enter the pump. I sourced a second hand pump and fitted it,however my 4x4 hasnt worked since. Iv had it on vagcom but no faults. So im assuming its the pump. I would be intrested in purchasing the pump provided it works.
    Mr.G's Avatar
    Nov 2008
    In a Tardis!!
    1,302
    My car developed a fault after i'd had the haldex oil and filter changed, wether someone had just highlighted a problem that was there already i dont know but now my ESP light is constantly on (the triangle warning light with a circle and arrow). I can hear some noise from the rear like a fuel pump, plus clicking noise. I know it's coming from the haldex unit as i've been under the car.
    I bought a used haldex unit complete. Including the subframe. I'm due to get it fitted within a few weeks. when the old one is off the car i'll get it tested and keep you informed.
    OK?
    G
    barters3's Avatar
    May 2008
    440
    That would be brilliant. Im off on holiday for a few weeks,so if you could pm me when you know what the score is and il get back to. Much appreciated.
