    Sep 2009
    ECU Engine temp sensor - difficult start when warm
    Car A3 1.8 (non turbo)
    I have read engine code problem of '' P0116 - Engine coolent temperature circuit range / performance problem '' Simply put when warm the engine is difficult to start, presumably because its firing more fuel in the engine thinking its cold?
    My question is, has anyone had this code reading before or symtoms and know exact fix? Or does anyone know where the ECU engine temp sensor is located to fix?
    a3emma's Avatar
    Sep 2007
    near gretna
    43
    my car has the same starting problems,but i dont no if i have that code. i changed the coolant temp sensor, and that never made a differance to mine, but mines a tdi (dont no if that makes it any different)but its probably worth changing to see if it does solve the problem.
    Feb 2009
    Macclesfield, Cheshire
    42
    Mine does this also (2.0FSI), its had a new coolant temp sensor, fuel pump, speed sensor and its still doing it! if anybody find a fix for this please let me know,
    James
    2004 Audi A3 2.0 FSI Sport, Deep Green Perlescent
    Sep 2009
    Did you replace the right temp sensor, am led to believe there are two??
    S3 Paul's Avatar
    Oct 2006
    2,764
    If possible read the temp on vag com or something like... it will read what the sensor tells the ecu. not the dash. they should be the same or the sendor is on its way out
    Noggy Blue 2001 S3
    Sep 2009
    Good Idea, will try and let you know
